Old 04-02-2005, 10:15 PM   #31
BlackKat's Avatar
Guys, Me and Axel run rubber tires on carpet. Thats how we run every class (except mod) in NorCal
Axel: Stick to the diff while your still learning the arts. A one-way will be hard for you to drive for a while.
BTW: If you get in trouble not having a ride again, try taking transit. VTA bus #68 will take you to Gilroy Transit Center which is a block from HW
BlackKat is offline   Reply With Quote
Old 04-02-2005, 10:23 PM   #32
axel's Avatar
I actually went to sheldon's, ed told me to use one-way. I didn't know he knew Hara?
axel is offline   Reply With Quote
Old 04-03-2005, 05:59 AM   #33
ChadCapece's Avatar
Don't forgot that that with a spool or one-way, a wreck will pull more amps causing the battery to go flat. You will lose the punch if you hit something while on throttle. This problem is less noticed in diffs b/c they give some and unlease the energy to the inside tire.
ChadCapece is offline   Reply With Quote
Old 04-03-2005, 07:09 AM   #34
eeyan's Avatar
Send a message via AIM to eeyan Send a message via Yahoo to eeyan
How's the tire wear difference though... between, a spool, diff and one-way!?
I know for sure that a one-way (due to efficiency) will make the tires last longer... and I heard tires on cars running with spools has uneven wear due to the extra "work" they have to undergo... especially the front tires.
TAOB Racing Team (1999 - 2011)
eeyan is offline   Reply With Quote
Old 04-03-2005, 09:01 AM   #35
ChadCapece's Avatar
Spool, extreme wear on front tires. Will go through front tires FAST
One-way, medium wear on front tires. Wear faster than rears, but consistantly rotating front to back will increase tire life.
Diff, low wear on front tires. The front tires wear slightly faster than the rear due to the front end dive during turn in. Rotating not that necessary.
Old 04-03-2005, 09:46 AM   #36
Send a message via AIM to greencactus3
if you dont count the damage from hitting walls, because of the less rub wont the oneway have the least wear as eeyan says?
greencactus3 is offline   Reply With Quote
Old 04-03-2005, 09:50 AM   #37
ChadCapece's Avatar
Actually, a one-way will wear more than the diff since the one-way is the same as a locked spool exiting the turn. A diff won't let the power go to the tire with the most traction, so the tires won't wear as much.
Old 04-03-2005, 10:31 AM   #38
is that what happens? i had thought the outside spins faster than the inside. but i guess on throttle the tires have just enough slippage to not let it spin the outter faster than the driven so it acts like a spool. huh. im glad i made this thread. im learning so much!
4wd front one-ways and spools BobWoodhouse Electric Off-Road 12 10-16-2007 12:31 PM
Spools DC Racing Electric On-Road 3 05-15-2007 10:34 PM
Spools... DirtyDog3375 Electric On-Road 9 04-26-2006 04:42 PM
One Way, Diffs and Spools? Fervidsea Electric On-Road 4 10-29-2005 08:13 PM
Understanding spools... Soviet Electric On-Road 39 06-18-2004 03:11 AM
