Xray T3 gear diff >
Xray T3 gear diff
Xray T3 gear diff
Old 11-13-2012, 03:16 PM
OVA
OVA's Avatar
Trader Rating: 82 (100%+)
Default Xray T3 gear diff
question:
What other brands rubber O ring will works for Xray T3 diff axles?
Mine Diff axles leaking bad ,it need replace the O ring ...Who sell them?
OVA is offline
Old 11-13-2012, 03:24 PM
Skiddins's Avatar
A lot of drivers don't bother with the O-ring, just use the paper gasket.
Skiddins
Skiddins is offline
Old 11-13-2012, 03:38 PM
OVA
OVA's Avatar
Skiddins
Are talking about the diff housing thin O ring ? I'm talking about the O ring goes inside the housing before the flat shim c/t outdrive...
btw I found some ..thanks
OVA is offline
Old 11-13-2012, 05:08 PM
Geezatec's Avatar
Go to LHS and see if they carry 25x.7 orings. Or go to xray part#971240 oring come in pack of 10.
Geezatec is offline
Old 11-13-2012, 05:11 PM
defcone's Avatar
Trader Rating: 15 (100%+)
Originally Posted by OVA View Post
question:
ive never had that problem have you been using that for a long time? maybe the diff housing has worn out? the orings should be fine and even if they swell up it should only stop the leaking.
defcone is offline
Old 11-13-2012, 05:35 PM
Danny-b23's Avatar
Unless he's torn them.
Remember to always put a drop of oil or green shock slime on any o-ring you install. Less friction= a longer life and a better seal.
Danny-b23 is offline
Old 11-13-2012, 06:20 PM
OVA
OVA's Avatar
I brought this car used and I don'r think the original owner was using the Xray O ring ,this one is clear color...like the SpecR..
OVA is offline
Old 11-13-2012, 06:27 PM
Danny-b23's Avatar
From what I remember (as it's been a while since I've built one from the package), those particular o-rings are clear even on the Xray diff. The previous owner may just have not prepped them properly.
Old 11-13-2012, 06:32 PM
arn671's Avatar
Trader Rating: 16 (100%+)
Default Teflon tape
wrong thread! good luck.
arn671 is offline
Old 11-13-2012, 06:35 PM
OVA
OVA's Avatar
This one look like the Spec R cause it has the groove and flange looking O ring ..I think the xray are just a simple O ring !
OVA is offline
Old 11-13-2012, 06:36 PM
Danny-b23's Avatar
This one look like the Spec R cause it has the groove and flange..I think the xray are just a simple O ring !
Ah ok. Well best advice I can give is replace with Xray parts, and it should work great!
Old 11-13-2012, 06:38 PM
OVA
OVA's Avatar
OVA is offline
Old 11-13-2012, 07:37 PM
defcone's Avatar
The spec r o rings shouldn't fit, is it a spec r diff?
defcone is offline
Old 11-13-2012, 10:53 PM
Dan
Dan's Avatar
Trader Rating: 63 (100%+)
edit
Dan is offline
Old 11-13-2012, 11:22 PM
Geezatec's Avatar
Stomer's Hobbies Search Part# XRA971240 25x.7 O'rings (10qty) $7.95. Lubricate w/slime or silicone grease, It'll blowup and seal better, also use torque sequence to tighten equally.
Geezatec is offline
