Cleaning Carbon Chassis from Protector >
Old 11-11-2012, 06:25 PM
Drift_Buggy's Avatar
Trader Rating: 22 (100%+)
Questions?? Cleaning Carbon Chassis from Protector
My chassis protector was starting to come up in a few places so just took it off. What is the best method to get all the sticky residue off the carbon chassis?
Drift_Buggy is offline
Old 11-11-2012, 07:01 PM
elee32's Avatar
Trader Rating: 18 (100%+)
motor spray.....or .5 mm of ride height
elee32 is offline
Old 11-11-2012, 11:04 PM
BCbud's Avatar
Trader Rating: 37 (100%+)
Try some isopropyl alcohol.
BCbud is offline
Old 11-12-2012, 12:57 AM
Really good thread!
caaraa is offline
Old 11-12-2012, 02:00 AM
heretic's Avatar
I would try WD40 before anything else. Works for sticker residue on bodies as well.
heretic is offline
Old 11-13-2012, 12:44 AM
Thanks, I'll give them ago and let you know which turned out best.
Old 11-13-2012, 01:09 AM
Troy Mckune's Avatar
Trader Rating: 46 (100%+)
Acetone or finger nail polish remover (same thing just smells pretty) will work the best.
Troy Mckune is offline
Old 11-13-2012, 11:57 AM
heretic's Avatar
Several highly qualified people (with degrees in related domains) told me they avoided as much as possible to use acetone on their CF plates of any kind. It may not damage the plate visually but the damage to the resin / fiber could be very real.
The only use I would make of it is maybe to remove fresh stains of CA glue when the edge prep goes a little wrong. Just a drop on a Q-tip.
heretic is offline
Old 11-13-2012, 12:49 PM
Acetone can be bit aggressive. Goo gone is great and won't ruin the carbon.
trigger is offline
