Old 03-30-2005, 03:25 PM   #1
Cooling batteries
As a newbie, i was wondering:
Do you use sth that is ready for sale at hobbystores or you build your own?
Capone_GR is offline   Reply With Quote
Old 03-30-2005, 03:39 PM   #2
nmt6789's Avatar
Send a message via AIM to nmt6789
A computer fan works good.
nmt6789 is offline   Reply With Quote
Old 03-30-2005, 03:55 PM   #3
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
There's some debate about it, but Fukuyama dosen't reccomend cooling your batteries on a fan at all. It can cause an imbalance in the cells. They should be allowed to cool naturally.
Jon Kerr is offline   Reply With Quote
Old 03-30-2005, 04:25 PM   #4
rctoyguy's Avatar
Trader Rating: 21 (100%+)
Gotta agree - best to let them cool on their own.
The tray you are talking about is probably an equalizing tray - used after the batteries are discharged, it pulls each cell down to .9v "Equalizing" them.
Jeff
rctoyguy is offline   Reply With Quote
Old 03-31-2005, 01:30 AM   #5
I have seen some trays with a 90mm fan and place for two batteries. They told me that is was from Trinity but seemed to be more like ''hobbystore made of'', no brand at all.
Old 03-31-2005, 01:59 AM   #6
John Doucakis's Avatar
Hi Capone,
Donīt use fans or any cooling device.
Different batteries need different charging settings and operate best at different temperatures.
For example:
VTEC 3700UP - 20mV - 50°C
GP 3700 - 5mV - ??°C
In Greece, during summer it is inevitable that our batteries will get very hot. Maybe in such case it is usefull to use a fan but not to keep them cool, just to avoid overheating...above 50°C
John Doucakis is offline   Reply With Quote
Old 03-31-2005, 03:00 AM   #7
Jack2's Avatar
Lightbulb
Yes thats exactly right. Some matchers actually say that you will get a better punch and all sorts af magical things if you dont cool them. I use a fan when discharging (30amps) because i discharge basically straight after the run.-other wise they would over heat
Schumacher Mi4CX
Mugen MTX & MRX
"He who dies with the most toys wins" - Phil Harris
Jack2 is offline   Reply With Quote
Old 03-31-2005, 05:45 AM   #8
Originally posted by John Doucakis
Hi Capone,
For example:
I think i will follow..
Old 03-31-2005, 11:05 AM   #9
Charlie O's Avatar
Default Naturally cool!
Naturallly cool, although you dont want to go over 150F. and if that's the case you may have your delta peak to set to high.
Charlie O is offline   Reply With Quote
Old 03-31-2005, 11:09 AM   #10
Jon Kerr's Avatar
Good point charlie. When you're charging, your cells should get to about 130-140F. They shouldn't get too much higher than that after the run either. If they do, you may want to watch the motor as well because you could have some other problems with the drivetrain adding additional strain to the motor and batts.
edit: Also, whatever you do, make sure the cells have cooled for a couple hours minimum before you re charge them again. Just because the surface is cool dosen't mean the chemicals inside are cool as well.
Old 03-31-2005, 01:46 PM   #11
Jack2's Avatar
EDIT- i will only use the fan in summer time. thats when they seem get to the point of almost overheating, during winter they stay quite a bit cooler naturally,and when i do use a fan its more just to keep the air flowing, just a little 80mm PC fan on 12v
Schumacher Mi4CX
Mugen MTX & MRX
Old 03-31-2005, 06:11 PM   #12
Very helpful tips (and money-saving!). Thanks guys.
grazianos is offline   Reply With Quote
Old 04-25-2005, 10:06 PM   #13
hi
dose eny one have a pic of one built
evo3s is offline   Reply With Quote
Old 04-25-2005, 11:02 PM   #14
NOZ69's Avatar
Here`s one i`ve built.. (to the right of pic) i mainly use it to cool the motor down after each race , just sit the car on top of it.
The pic to the left is my Discharger
Cheers
FT TC4, LRP TC Sphere, LRP X-11 13.5
SC10 4x4
M03M Suzuki Swift
Power by Feral
Sanwa MX-3 FHSS
NOZ69 is offline   Reply With Quote
Old 04-25-2005, 11:27 PM   #15
how big is the fan
Cooling batteries while charging bigdog xxx-s Electric On-Road 30 10-17-2004 01:16 PM
5v cooling fan Speedie Electric On-Road 30 09-08-2004 07:48 PM
Cooling Fans under batteries Kennedy Australian Racing 2 08-28-2003 03:29 AM
Cooling Batteries While Charging Calvin Ng Electric On-Road 38 08-27-2003 02:48 PM
Can I run with a cooling fan Franky Australian Racing 5 07-17-2003 06:40 PM
