Old 11-09-2012, 11:38 AM   #46
Originally Posted by locked View Post
Tires (and people) sometimes come unglued. It can lead to erratic behavior.
Outstanding
Bb
bucketboy is offline   Reply With Quote
Old 11-09-2012, 11:43 AM   #47
Regional Moderator
CarbonJoe's Avatar
Originally Posted by bertrandsv87 View Post
The gluing tire days are over rookie ! Everybody here race on preglued spec tires
Just because they came pre-glued from the factory doesn't mean that they can't come unglued. Not every tire manufacturer has the same quality control as well.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 11-09-2012, 11:44 AM   #48
orcadigital's Avatar
Trader Rating: 61 (100%+)
The gluing tire days are over rookie ! Everybody here race on preglued spec tires, and I don't have to explain every detail on how to shim them, so they won't wobble.... Maybe I'll have to in your case, but I doubt you'll understand... Your post count is very low I see, and I can guess your IQ....
While it has not happened to me, and I am unsure of the tires the original poster is using, pre-glued tires do not always stay glued. I have been told Much More tires are notorious for coming unglued (on the pre mounted rubber TC slicks). My Sweeps (QTS as well as open race rubber) and Jaco Blues have never come unglued. My VTA tires that I glue myself...different story...we won't go there.
Desoto Racing * Serpent America * Boca Bearings
"I was doing fine until about mid-corner when I ran out of talent."
orcadigital is offline   Reply With Quote
Old 11-09-2012, 01:24 PM   #49
Xenolance's Avatar
Talking
Originally Posted by Luke Hobson View Post
10 hours... Your not rebuilding a space ship tiger....
David Rose, Houston, TX.
Spec-R R1 / S1, Corally RDX.
"He's a Picasso with an Allen wrench." -Guffinator
Xenolance is offline   Reply With Quote
Old 11-09-2012, 05:21 PM   #50
Luke Hobson's Avatar
Send a message via MSN to Luke Hobson
Sorry it sounds like I missed all the fun while I was at work
In my experience, you should check the gluing of your tires every run as a matter of course.(at the same time as you clean them)
The only tires I've come accross that don't come unglued after several runs are pre mount Sorex done at the Schumacher factory. They're excellent.
I think the Jaco blues I used in Vegas the other year were good aswell...
Luke Hobson
Awesomatix - Xenon - Godzilla Paint - Moorespeed - ToniSport - MBmodels
http://luke-hobson.blogspot.com/
Luke Hobson is offline   Reply With Quote
Old 11-09-2012, 06:26 PM   #51
Lessen's Avatar
Send a message via MSN to Lessen
I've recently experienced a pre-glued Sweep losing nearly the entire bead. Chased a setup problem all weekend only to find the tire issue on Tuesday.
Car still needs a rebuild though..
"Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. "
Lessen is offline   Reply With Quote
Old 11-09-2012, 09:16 PM   #52
Regional Moderator
CarbonJoe's Avatar
Be careful! I've heard it's going to take 10 hours.
Old 11-13-2012, 12:57 PM   #53
Trader Rating: 41 (100%+)
Done the rebuild as the Tire was not all the issues. The rear sway bar mounts were super sloppy and not giving it the correct action. Fixed the glaring issues and reset the car back to a know setup. Will be testing tomorrow. I am amazed at the setup possibilities with this car. Have only TC4 and FT tc4 experience it's a bit different to setup but very nice.
Since this car is in VTA trim I will be playing with roll center as on my TC4 I really like a low Low Low roll center but looking at 98% of the setups for this car online the roll center settings are way higher than I would have thought.
______________________________________________
Jason Deadman
I race toy cars for fun. If I need to explain, you'll never understand.
jdeadman is offline   Reply With Quote
