Old 11-08-2012, 09:24 AM   #31
sosidge's Avatar
Originally Posted by Timbo99 View Post
I found this post very interesting,as I have had all four corners ok,but the car was tweaked when I throw it on my Hudy setup station,which I do in between runs.
So basically,I think a good rule is weight distribution is a great guide,but not actually right for checking tweak.
What do you think?
Cheers
Tim
Mechanical tweak is just in the build - you don't need a setup station to make sure the car is built straight, just a flat board.
On weight distribution "tweak" - you should trust the scales.
Old 11-08-2012, 09:50 AM   #32
Suspended
Smile
Tweak is not important enough to take the crown! I think a tweaked chassis can be faster around the track than a balaned one, just that it needs to be unbalanced is the right direction: more weight on the inside of the fast turns... If the slow turns are really tight, than less weight on the inside tires to make these turns. That's why oval unbalanced cars go so fast around bends... It also should not be taken to extremes, but 100grams or so extra on the inside tires in fast turns is good to have if the opposite turns are fairly slow turns. You really need good balance if you have fast turns in both directions, but most tracks have faster right turns than left turns, at least in the US..... Also the Sodige that keeps following me on every thread, it's not that kind of closet thread !!!
bertrandsv87 is offline   Reply With Quote
Old 11-08-2012, 09:57 AM   #33
Suspended
Who knows what the picture on your profile means !
Old 11-08-2012, 11:11 AM   #34
What do you think?
Cheers
Tim
When you set your car up on four scales, did you make sure to level the scales first? The scales need to be leveled just like a tweak station or the results will not be good. I spend hours making sure my scales were perfectly level. This is why I only use the scales at home. It would take far to long to level everything at the track.
jha07 is offline   Reply With Quote
Old 11-08-2012, 11:30 AM   #35
Trader Rating: 49 (100%+)
Originally Posted by locked View Post
Make sure whatever settings that you think are supposed to be on the car are actually precise and even left to right.
I've seen some extremely wacky camber, droop, toe, etc., but the driver thought he was running {insert pro driver's name here}'s setup on the car. :P
I'm a crappy mechanic as far as playing around with settings. I ran a completely kit setup for a whole year on one of my cars, but it was a precise set up that I maintained well. Usually when some handling issue cropped up, it was because I either cracked a rim or the tires started pealing off the rims and needed to be reglued or replaced. That's something to look for, especially if you run Sorex 28 or 32. They usually start to peal away from the rim after a couple of runs in high traction (actually kind of tears away from itself near the glue line)
Definitely guilty of that one..... at least a couple times......
SpeedMerchant Rev7
oceanhighz is offline   Reply With Quote
Old 11-08-2012, 01:01 PM   #36
Suspended
Also if you can consistantly check your tires for roundness, whether old or new; it's probably more important than all of the above....
Old 11-08-2012, 01:10 PM   #37
Originally Posted by sosidge View Post
Oh, and ignore EVERYTHING bertrand-blah-blah says... that is the best bit of advice you will read on RCTECH.
JamesL_71 is offline   Reply With Quote
Old 11-08-2012, 06:05 PM   #38
Suspended
Smile
Quite patriotic James ! Anyways it seems the four most important ones would be in that order :
First: Roll Centers
Second: Droop/Ride height
Third : Camber
Fourth : Toe
All of those with the right weight, tires, and lowest CG possible.....
Old 11-08-2012, 06:30 PM   #39
tonnes of information.. Thanks all.
______________
~TC6.1~Tekin RS~Futaba bls451~Futaba 4pk~FS603
www.programmerhaven.com
FourWheels is offline   Reply With Quote
Old 11-08-2012, 06:42 PM   #40
Lessen's Avatar
Send a message via MSN to Lessen
What do you think?
Cheers
Tim
If your chassis is very well balanced (built well), then corner loads will be a very accurate and reliable way to verify tweak. I have the Hudy tweak tool and NEVER use it after I understood how to analyze corner loads and apply the data. When I first got scales I struggled to understand the dynamic between measured corner loads, ride heights and chassis tweak. I took some time going back and forth between scales and the tweak tool until it dawned on me what was going on. Here's what I do...
-Check ride height at four chassis points. I always measure behind the front wheels and forward of the rears.
-Adjust pre-loads according to your particular setup
-Put the car on scales. If tweaked corner loads are observed I adjust accordingly (Add preload to the corners that are light compared to their L/R counterpart, decrease preload to the corners that are heavy. Adjust all 4 corners equally! ie. 1/16th turn)
-If adjusted corner loads get the car equal (and you properly adjusted preloads equally) then you should be able to observe ride heights as the same as was initially measured.
-If you cannot get the corner loads equal left to right (most likely you may get either the front pair equal but the rear is still off or vise versa), then your chassis is tweaked. As has been previously explained by others, loosen chassis and/or top deck screws and retighten. Don't be surprised if you do this then get corner loads nearly exactly where they need to be right away with no further adjustments.
I know it sounds like alot but it actually goes very quickly. I find it very convenient and reliable.
"Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. "
Lessen is offline   Reply With Quote
Old 11-08-2012, 06:49 PM   #41
Radio Active's Avatar
The poster asked about tuning settings. Tweak is not a tuning setting, it's something that must be the same every time!
Reigning NSW 4WD Group 20 Champion
Member: Maitland Radio Car Club (http://www.morcc.com.au)
twitter: @dvcotton
Australian 12th Scale hastag: #EP12AU
Radio Active is offline   Reply With Quote
Old 11-08-2012, 06:59 PM   #42
Yup, great points.
by tuning settings I meant what normal settings one should check after a round of racing especially if you hit the car several times
______________
Old 11-08-2012, 07:00 PM   #43
Lessen's Avatar
Well... if you don't check it and it's wrong, the car will handle like garbage.
Yes, the thread got slightly off topic. However, the discussion underlines why it is important to check it at least somewhat regularly. I think whether it's appropriate or not to designate it as a "tuning" item is neither here nor there. Most everybody seems to agree checking it is very important.
Old 11-08-2012, 07:09 PM   #44
True enough, but if you came to the thread, after reading the title, wondering what parts you should change on your TC to alter the handling for different conditions...
twitter: @dvcotton
Old 11-08-2012, 07:30 PM   #45
Lessen's Avatar
Do you have anything beneficial to add to the thread or are you content with nit-picking the differing interpretations of its title?
That is rhetorical.
