Old 03-29-2005, 06:32 AM   #1
Exclamation Battery Charge #'s...
I just purchased the LPR Pulsar Competition 2 charger and some GP3300 bulk cells. Upon my first charge I was fairly suprised to see 4100mah and 8.9v when it was complete? It charged at 5 amps a little over 45 minutes.
Does that sound good? bad?
Thanks!
Nitro-Boy is offline   Reply With Quote
Old 03-29-2005, 06:45 AM   #2
Exe
Exe's Avatar
Send a message via ICQ to Exe Send a message via Yahoo to Exe
people get 4000 when charging, but charge number do not count, as the real numbers are when you discharge the battery... i guess you get 4100 because the resistance is high
Exe is offline   Reply With Quote
Old 03-29-2005, 06:49 AM   #3
i can't remember the name ( maybe rc extreme) but one of the lastest issues of a magazine has a good article on what all the numbers mean, and shows you a way to make your own discharge graph.
Turtlemaster is offline   Reply With Quote
Old 03-29-2005, 06:52 AM   #4
crimson eagle's Avatar
Send a message via ICQ to crimson eagle
Input Mah is linked to output Mah but it's not a direct thing and it does vary quite a bit. I had some cells go to 4500 Mah on the first charge and regularly hit 4300 in subsequent charges. But Exe is absolutely right, the most important numbers are on discharge.
Chris
crimson eagle is offline   Reply With Quote
Old 03-31-2005, 01:42 PM   #5
well after running the battery I discharged it down to 5.4v and these are the #'s I got:
Discharge Current 10amp discharge
Discharge Voltage 5.4v
Displayed after discharge:
395s
7.08v
1089mah
Does that mean anything to anybody?
Old 03-31-2005, 01:53 PM   #6
Exe
Exe's Avatar
395s
7.08v
1089mah
that ain't right... you should get approx 370-380 of runtime and 3000-3100 capacity at 30 amps, not 10... something's wrong there mate...
Old 03-31-2005, 02:41 PM   #7
Exe,
This was AFTER he ran the battery.
Nitro,
It means that after tour race you had nearly 400 seconds of run time left at 10A discarge, thats fine, nothing to worry about. You might want to gear up as you have a lot left in your cells.
Also I would suggest you do not discharge below 1v/cell. There is a slight risk of cell reversal.
Chris.
Old 03-31-2005, 02:43 PM   #8
Exe
Exe's Avatar
Originally posted by crimson eagle
Exe,
Nitro,
Chris.
aah.. sorry, my fault didn't read that carefully
Old 03-31-2005, 04:28 PM   #9
Default $.02
The peak voltage # of 8.9 is telling you your pack is close to new and has pretty good internal resistance. As the packs get older, the peak voltage will go up. As internal resistance goes up, so will the peak voltage. 8.9 volts are a good peak.
David Root is offline   Reply With Quote
Old 03-31-2005, 06:48 PM   #10
Thanks for everyones input!
Just to see I re-charged the pack fully and then ran a discharge to 5.4v (Before reading the 6v, I'll do that from now on):
Charge from 5.4v:
6amp
8.41v
3024mah
Discharge to 5.4v:
10amp
7.31v average
2615mah
948s
Initial Battery Charge $$$... Electric On-Road 2 03-15-2013 04:40 AM
wtb m8 rechargable battery and charge will g R/C Items: Wanted to Buy 0 09-12-2007 11:36 AM
Charge Battery catkchun Malaysian R/C Racers 20 09-12-2007 12:28 AM
First Battery Charge on new IB3800's MAD916 Electric On-Road 2 11-06-2005 02:25 AM
Can I charge a battery while wired to my ESC? Bob Nilsen Electric On-Road 30 02-16-2005 08:16 PM
