Steering knuckles ballstud threads keep stripping. need advice. >
Old 11-04-2012, 05:58 PM
gom
Default Steering knuckles ballstud threads keep stripping. need advice.
Have anyone experience the issue where the steering knuckles top threads would stripe when you tap the board sightly.
I hit the board once or twice per race day. All it takes is one tap and the thread stripped. I kept changing the steering knuckles. They aren't expansive. But I am wondering if there is a way to fix this permanently. A guy at our track suggested CA glue it. I am not too sure about that...
Any help would be greatly appreciated.
gom is offline
Old 11-04-2012, 06:18 PM
I'm sure you've already considered this, but is it possible you are screwing them in too tight so that all it takes is a little nudge to completely strip them out?
Vostok 7 is offline
Old 11-04-2012, 07:01 PM
gom
Yes I did. So I made sure that I didn't tighten it too much for the pass few months. But it still stripped....
gom is offline
Old 11-04-2012, 07:05 PM
B00t13g's Avatar
What car? Some companies make aluminum steering blocks. Try ca it should work.
B00t13g is offline
Old 11-04-2012, 07:27 PM
Jochim_18's Avatar
No matter what car bottom and top screws comes loose overtime even we just normal usage without crashing, your best bet is just get the aluminum knuckle. I do replace the plastics ones on my tamiya 417x if their noticeable play this is the signs it's wearing out.. And I'm tired of replacing it so I'm going to get some aluminum ones...
Jochim_18 is offline
Old 11-05-2012, 09:06 AM
gom
I have a TC6 and a Tamiya TA06. both steering knuckles strips pretty easily.
I think I might just CA them....
gom is offline
Old 11-05-2012, 11:03 AM
Marv's Avatar
CA = bad idea (IMO)
medium strength lock tite
blue medium loctite
Most any hardware store, auto parts place etc has it.
Marv is offline
Old 11-05-2012, 11:15 AM
MikeXray's Avatar
Trader Rating: 73 (100%+)
Change to a buttonhead screw through the bottom into a female ballstud, this will take the plastic threading out of the mix.
MikeXray is offline
Old 11-05-2012, 12:21 PM
CA won't hold up in a stress area.
AreCee is offline
Old 11-06-2012, 08:10 PM
gom
Originally Posted by Marv View Post
CA = bad idea (IMO)
blue medium loctite
i tried that exact blue locktite. but no luck. it still stipped. thanks though.
gom is offline
Old 11-06-2012, 08:11 PM
gom
That's a neat idea. I'll give it a try. Thanks alot.
gom is offline
Old 11-07-2012, 01:17 AM
caaraa is offline
Old 11-07-2012, 01:33 AM
tc3team's Avatar
I used to have the same problem with my trf415msxx. (Our track has wooden track boards).
I changed to Aluminum uprights and the fault has gone.
I dont know how the uprights are constructed on either of your cars, but I made sure the top hat inserts (I don't know the proper name for them) on my car we replaced at the same time as the upright, the ballstud and the steering arms to eliminate any wear which when combined in the parts might be detrimental in a crash.
I found that countersunk screws are better on the lower mounting too, not button head, or it may just be coincidence!
I am wondering if the fault was caused by excessive steering lock on impact, as I turned the steering lock down a bit too and I think that helped as well as the new parts.
Glue of any kind doesnt usually help, (I tried that too) especially CA as it will probably attack the properties of the steering arm and make the thread worse.
tc3team is offline
Old 11-07-2012, 05:21 AM
Adam B's Avatar
Everybody with the TC6 at our track went to the alum knuckles. Granted hitting the boards don't help, but this was a common problem for even the clean drivers.
Adam B is offline
Old 11-07-2012, 05:26 AM
mtbboy's Avatar
Simple soloution.
10 mm ballstuds,
Never pull one out again.
D.
mtbboy is offline
