Kyosho Plazma Formula 1
#76
Was in the Chicago/Joliet area this past weekend. Was able to get the Plazma F1 some exposure to the masses in Leisure Hours hobby shop in Joliet. Many were impressed with the car, its build, and its layout. Might get some converts to the Plazma F1 that are currently rolling Tamiya and Yokomo.
#77
#82
Is there a way that I can make this car to 190mm?
#83
Ok, last 2 questions, for now at least. I'm thinking of going with the Zen Ferrari 641 for the body but am concerned about the back of the body being too tight and not clearing the rear motor pod and side links. Attached pic below:
Also probably go with Zen mounted foams-I'm thinking a little harder on the fronts-correct?
#85
#86
I've read the whole thread, and although I don't yet have a plazma f1 I think I can answer your question.
To make the rear 190 you would have to use F104 tires. On the front it's a little trickier: you can try F104 tires but I think what some else did was put on the whole front end of a f104. Hope this helps.
Or click on this:
http://www.rctech.net/forum/electric...ula-1-a-2.html
Ed D.
Or click on this:
Ed D.
Last edited by Ed Delgado; 10-16-2013 at 11:27 AM. Reason: Added link to page 2 of thread .
#87
Or click on this:
Ed D.
Or click on this:
Ed D.
Dean
#88
Yea my front end conversion did not turn out so good. I had all the parts (digging through the F104 manual and ordering them separately) but I did not have a F103/F104 chassis to use as a template to drill the new holes as "eff_one" had with his. I must have been slightly off on one of my holes and there was too much stress on the plastic parts from Tamiya. Lasted 2 minutes before one of the front plastic pieces snapped. Ended up going back to the Kyosho Front End.
Dean
Dean
I guess I need to make myself a 190mm front out of CF in order to follow UF1 Rules
