Trouble setting up esc
Hello, I just got in a LRP IPC Pro Sport esc. I reset all the settings on it and set it up accordingly to the instruction manual, but I can not get any throttle out of it :weird: Any ideas?
did you check if your wires to motor are intact? and did you try without pinion to make sure its not the drivetrain?
Yes, all my wires are connected properly...and the motor pinion was off...I was trying to mess around with my M8 settings but still got nothing...
LRP spedo set up goes like this radio on car on hold down setup button until light goes solid release button push button again until motor pulses release pull ful throttle push button release full break push button release should be good to go if it does not work start over again it should work the first time
