Shopping for small VTA esc? >
Old 10-28-2012, 07:35 AM
RCknight's Avatar
Default Shopping for small VTA esc?
Ok, I think it's time to shop, replace my GTB with something smaller for VTA. Baa...I like Tekin RS in case I want to run a faster class someday, but can't use a timing esc. So....I like the price and size of the spec Novak but the resistance rating is higher. The Novak GTB2 with xdrive seems nice but it's about same size as my GTB. So what are some good options here?
RCknight is offline
Old 10-28-2012, 07:48 AM
Trader Rating: 49 (100%+)
Hobbywing justock
oceanhighz is offline
Old 10-28-2012, 07:58 AM
Trader Rating: 102 (100%+)
Originally Posted by oceanhighz View Post
Hobbywing justock
x2 on this! Great speed control and it is 49.75 right now. I ordered mine and had it in 3 days!
http://www.falconsekido.com/products...c-esc-for-1-10
ricerscott is offline
Old 10-28-2012, 08:25 AM
RCknight's Avatar
Wow I'm impressed, does it have a Novak style motor plug?
RCknight is offline
Trader Rating: 38 (100%+)
Is that hobbywing smaller than the ESC he is replacing? If you are limited to a speed control that doesn't allow timing in any configuration the Novak Edge will be the smallests. The Speed Passion Reventon Stock Spec is also a good choice and a bit smaller than the GTB but not as small as the Edge.
linkless is offline
Old 10-28-2012, 08:35 AM
markt311's Avatar
Trader Rating: 32 (100%+)
The Hobbywing is 28mm x 32mm pretty small. Standard sensor port
markt311 is offline
Old 10-28-2012, 08:44 AM
DARKSIDE's Avatar
the Edge is the smallest esc on the list(mongoose), the Speed Passion Citrix is next...
DARKSIDE is offline
Old 10-28-2012, 08:59 AM
Trader Rating: 27 (100%+)
I can attest to the fact that the justock is smaller than a Novak GTB and a GTB2. It's just about the same size as a Novak Edge.
Before I switched to the Hobbywing, I had to mount my receiver on top of my servo (stupid Airtronics receivers are so large) when I used the GTB2. After switching, I can get it all down onto the chassis.
hyujmn is offline
Old 10-28-2012, 09:08 AM
Price wise, I'd take the hobbywing justock over the edge and ive had 2 edges for about a year, counting lights and memorizing gets old compared to using the program card.
Old 10-28-2012, 10:46 AM
RCknight's Avatar
I've always run Novak, but I may venture out this time. Novak seems to be re labeling, and considering production costs over performance. Where's the small, compact, and low resistance stock est? Nothing fits the bill, so I may try this one. Thanks for the info.
RCknight is offline
Old 10-28-2012, 11:29 AM
Reflex racing has the hobbywing esc if you don't want to order from overseas.
anr211 is offline
Old 10-28-2012, 12:19 PM
CraigMBA's Avatar
Trader Rating: 22 (100%+)
Why do you say that? Just curious.
CraigMBA is offline
Old 10-28-2012, 12:44 PM
Moderator
Deja Vu's Avatar
I too have to ask why do you say that?
There are a lot of re-labeled ESCs out there, but Novaks aren't one of them. They are typically price competitive and competent. I run them almost exclusively anymore.
The Novak Club is another option for VTA. It's even less costly than the Edge, is just as tiny and works well for the class. I am running 3 of 'em now with no trouble and my cars are very competitive (in the hands of a good driver lol).
Deja Vu is offline
Old 10-28-2012, 12:45 PM
YR4Dude's Avatar
Trader Rating: 44 (100%+)
The program card is another $20 on top of the cost of the speed control. It is a necessary must have to program the Juststock. Although the instructions says you can program using the set button on the switch, it is almost impossible to do so.
Also the program box will allow you to download the latest firmware for the speed control. This is a must have because the new firmware fixed the speed controls problems of not having enough brake out of the box.
YR4Dude is offline
Old 10-28-2012, 12:54 PM
I've never had a problem programming via the lights on the Hobbywing, just the same as a novak. I happen to have a program card because I have another of their esc's in my WGT.
