Belt missing a tooth >
Old 10-22-2012, 10:05 PM
gom
Default Belt missing a tooth
Is it alright to keep running the main belt if it's missing a tooth? I ran a couple packs with it already. It still working.
Should I replace it in case something goes wrong?
gom is offline
Old 10-22-2012, 11:20 PM
vabroom's Avatar
There shouldn't be a problem. If I remember right, guys were cutting every tooth on their belts to lower the friction.
vabroom is offline
Old 10-23-2012, 09:01 AM
gom
That's good to know. Thanks.
gom is offline
Old 10-23-2012, 09:07 AM
Essnowyt's Avatar
That practice ended with the LOSI XXX.
I would not recomend cutting belt teath with the modern belted cars.
Snowy.
Essnowyt is offline
Old 10-23-2012, 09:09 AM
UrabusDenis's Avatar
I think there shouldn't be a problem, but I would definetely replace it
UrabusDenis is offline
Old 10-23-2012, 11:04 AM
Run it, Have fun and get a spare for when or if it breaks!!
uatemycookie is offline
Old 10-23-2012, 11:10 AM
Its not the right ratio if you are on the 4wd system since the belts are driven by internal ratio and a tooth missing might slow down one of the gear train.
clutch81 is offline
Old 10-23-2012, 11:11 AM
PMSL!
cyclonetog is offline
Old 10-23-2012, 11:57 AM
one tooth on the belt should work . youll have to have a replacement ready when it breaks. or has excessive play causing it to slip .. until then have fun and get some life out of it ..
mb racer is offline
Old 10-23-2012, 12:59 PM
gom
Thanks for all the great response guys. Will definitely get a spare asap.
gom is offline
Old 10-23-2012, 01:55 PM
quote of the year award
sidecarphil1 is offline
