Viper vtx1 vs Tekin RS >
Old 10-20-2012, 09:32 AM
WRR
Default Viper vtx1 vs Tekin RS
Hi all. Probably a thread about these matters but they tend to get really long and hard to find facts within.
New to the 1/12 game and want to know what is fastest these days?
Need a quick answer cuz the shopping cart are done and I want to hit check out as soon as possible while the stuff is all available
Both are rather small and viper deliver with a voltage booster. That much I know. But which one is the fastest with which motor?
Oh, and I talk about 13.5 boosted
Thanks in advance. Alex
WRR is offline
Old 10-20-2012, 09:40 AM
wingracer's Avatar
Trader Rating: 24 (100%+)
Tekin is king IMO for boosted. Viper is right there with it though. I would go Tekin not only for performance but the frequent updates and excellent support. Viper would be a very close second for me but it does have a few extra features that may make it even better. Also, the 1s viper does not need a booster or receiver pack.
wingracer is offline
Old 10-20-2012, 11:06 AM
klaymon's Avatar
Trader Rating: 71 (100%+)
So, does the Tekin require something extra to run 1S? I'm looking to get into 1/12 also and I have an RS I could pull from another car, but wondering if it's all I need.
klaymon is offline
Old 10-20-2012, 11:32 AM
WRR
Yes, you need an additional voltage booster like the one from novak. Your radio gear will not work on 3,7volts so you need to amp up to 6v at least. A small module that you fit between the battery and speedo and then connect to the receiver.
WRR is offline
Old 10-20-2012, 11:46 AM
wingracer's Avatar
Or you can run a receiver pack. I use a little 180mah lipo wired into the switch.
Old 10-20-2012, 12:32 PM
Trader Rating: 88 (100%+)
I used one of these when I ran a Tekin in WGT, much cheaper than the Novak booster and it worked perfectly
http://www.hobbyking.com/hobbyking/s...dproduct=11784
tcdrvr2 is offline
Old 10-20-2012, 12:33 PM
Double post sorry
tcdrvr2 is offline
Old 10-20-2012, 12:38 PM
WRR
And back on topic please
WRR is offline
Old 10-20-2012, 02:14 PM
nikos2002's Avatar
Trader Rating: 30 (100%+)
You can check our our website for more information and see winning and A Main set ups from IIC (International Indoor Champs) a few weeks ago. VTX1 results - 1st Expert WGT, 2nd 17.5 1/12, 5th in Mod 1/12, 10th in F1
Please let me know if you have any other questions.
nikos2002 is offline
Old 10-20-2012, 02:18 PM
I've ran both and both are really good. I recently switched to a Viper because I was getting tired of running a separate voltage booster and the Viper does not need one. I noticed right away that the Spektrum receivers that I was having some glitching issues with stopped having issues. So the built in voltage booster is quite strong. The all aluminum case is pretty cool and the programming interface is nice because you don't have to unplug anything to program it. As for the Tekin having an external voltage booster can be a good thing depending how you think of it. If the voltage booster goes out you just have one little thing to replace instead of a whole ESC. As wingracer noted the Tekin is pretty much the king of boosted racing so if the track in your area runs a boosted class that's something to consider. I haven't tried the Viper in boosted because all our racing is blinky so I can't comment there. The Viper does seem a bit smoother on the low end throttle control but unless you are driving in low grip conditions you probably will not notice the difference. Though the websites list differently...the footprint of both ESCs are identical except one is 90* from the other. So size wise the Tekin will take up slightly more room with the voltage booster. The Tekin is alot lighter so balancing your car left to right is easier. The Viper's smart braking system is really interesting but the Viper doesn't have a push control and Tekin does. Both companies have EXCELLENT support. Both Randy from Tekin and Nick from Viper are active on the forum and helping people with their issues and both were also at the IIC and helped the members of our group with their issues.
Basically it is going to come down to preference. You can't go wrong with either ESC.
InspGadgt is offline
Old 10-20-2012, 02:40 PM
S.Stew's Avatar
You should also consider the hobbywing xerun 1s. I've had great success with mine and so have many others. Probably cheaper than both the viper and the tekin too.
S.Stew is offline
Old 10-20-2012, 11:27 PM
Trader Rating: 38 (100%+)
As long as you don't mind rolling right past your spot on the starting grid because the brakes are non-existent at low speeds you should be fine with either. If this is an issue for you, get a Hobbywing or the Speed Passion 2.1EX. Yes, I find this issue truly annoying.
linkless is offline
Old 10-21-2012, 12:23 AM
The stock brake setting is virtually non-existent...once you bump it up I get plenty of brakes.
Old 10-21-2012, 12:54 AM
303slowdown's Avatar
The thing about built in boosters is when they go bad your esc is worthless. I personally would rather replace a $3 booster than a $100+ esc
303slowdown is offline
Old 10-21-2012, 12:58 AM
These where all blinky classes ( except mod 1/12) so this info is not very helpful for boosted comparison.
