Old 03-24-2005, 08:43 PM   #1
TurboFC3S's Avatar
Send a message via ICQ to TurboFC3S Send a message via AIM to TurboFC3S Send a message via Yahoo to TurboFC3S
Default TC2/C2 and JR Rx Incompatability?
Alright, I'm going nuts here ... I have 5 JR Receivers, none of them will work with my Novak TC2 or C2 ESC's. However, when I hook up the speed controls to my Tekin, Hitek, or XXTRA receiver they work just fine. Is there some sort of incompatibility that I don't know about? There's no other way to explain this
TurboFC3S is offline   Reply With Quote
Old 03-24-2005, 08:46 PM   #2
RodneyB's Avatar
I used to use a TC2 and two different JR receivers all the time. No problems.
Kyosho America; Peak Racing; Grandview Hobbies; CRCRC
CRCRC club administrator
Kyosho RB6, Kyosho ZX6, Kyosho SC6, Kyosho MP9e TKI
RodneyB is offline   Reply With Quote
Old 03-24-2005, 08:49 PM   #3
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Check the wiring on the "stock" JR receiver...It may be wired "backwards"
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 03-24-2005, 08:54 PM   #4
TurboFC3S's Avatar
Whatcha mean by that?
Old 03-24-2005, 11:44 PM   #5
maybe its not z connectors, maybe thats what he might have meant
Totalfixation is offline   Reply With Quote
Old 03-25-2005, 07:39 AM   #6
k_bojar's Avatar
Exactly...Before Airtronics released its "Z" connectors, they had a different plug wiring than Futaba...So if you used an airtonics receiver/radio, you needed to reverse a couple of the wires (don't remember which) to match the receiver...
So with that said...I'm not sure if JR uses the "universal" plug wiring that novak and futaba uses....I'd look at your manual and see if they tell you where the positive, negative and signal wires need to be plugged in...
On the novak unit...the red is postive, black is negative and white is the signal...I think JR uses different colors, but you should get the idea...
Sorry for the cryptic response...
