Old 03-24-2005, 06:10 PM   #1
revzalot's Avatar
Default Brushless maintenance
I know Novak says zero maintenance but dirt will definately build up escpecially around the bearings. What do you guys do for maintenance? Any good sites?
revzalot is offline   Reply With Quote
Old 03-24-2005, 06:41 PM   #2
Registered User
RC Noob's Avatar
Send a message via AIM to RC Noob Send a message via MSN to RC Noob
all you really need to do...is seal up the holes where dirt might get in...and once in a while, oil the shaft and clean the bearings and get all that dirt out..but that is about it
RC Noob is offline   Reply With Quote
Old 03-24-2005, 06:59 PM   #3
Default Novak ss5800 thermal cut
My SS5800 has thermally cutoff when using with new cells.
When use with my old packs, they are OK. Thermal cutoff happens once in a while when weather is hot.
Gearing is close to 7.5.
ah_liang is offline   Reply With Quote
Old 03-24-2005, 07:15 PM   #4
revzalot's Avatar
What new cells you running? The Intellects? Maybe it's wise to add fans for those hot days.
Old 03-24-2005, 10:10 PM   #5
Registered User
RC Noob's Avatar
im running gp3300s....but i dont know about other people..
Old 03-24-2005, 10:49 PM   #6
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
Default Re: Novak ss5800 thermal cut
Just put one of those little Reedy fans on the speed control, over the fins...works great. It drops the temps by 40-50 degrees.
It really shouldn't thermal that easy though...you might want to send it in. I had one that would thermal easy and I exchanged the ESC and it hasn't thermaled since...even geared down in the low-mid 5's.
Turbo Joe is offline   Reply With Quote
Old 03-25-2005, 12:11 AM   #7
I read from somewhere that the early batches of SS5800 had thermal sensitivity problems. Maybe mine is one of them, had it over a year now.
Old 03-25-2005, 12:53 AM   #8
Turbo Joe's Avatar
That could be the case...mine was a VERY early one.
Old 03-26-2005, 11:08 PM   #9
17driver's Avatar
R/C Tech Charter Subscriber
A guy I race with has had his system for 6 months and has not done a thing to it,and it works without any problems.
Midwest malitia member
17driver is offline   Reply With Quote
Old 03-27-2005, 08:44 AM   #10
Turbo Joe's Avatar
I ran mine since they came out (2003?)...I didn't notice anything until I tried to gear it WAY past the recommended gearing.
I love mine. I won't race at a track that doesn't allow them.
Old 03-27-2005, 09:04 AM   #11
revzalot's Avatar
I find the wires on the brushless are too bulky. You guys think 16ga wire will suffice?
Old 03-27-2005, 12:35 PM   #12
kufman's Avatar
It would probably work, you will just lose performance if the wires can't pass enough current.
Brushes? We don't need no stinking brushes!!!
kufman is offline   Reply With Quote
Novack brushless maintenance? LadiesFirst Electric Off-Road 5 02-24-2008 10:18 PM
what maintenance?? bigboss Nitro On-Road 3 10-09-2006 09:58 PM
Brushless motor maintenance uniquexme Electric On-Road 32 05-26-2006 12:14 PM
Maintenance For Your Gp Car mop_iko Rookie Zone 8 06-10-2004 01:07 AM
maintenance? cHckbOY5 Nitro On-Road 2 06-08-2003 07:22 AM
