Old 07-24-2002, 01:08 AM   #1
Erik R.'s Avatar
Default Simple Green
I'd like to get some feed back from people who use Simple Green on their rubber tires. Mainly how does it work? and when do I use it? I'd also like to know if you dilute it at all and how often you apply it. It seems like it could be useful information since Roar is limiting traction compound to this for rubber tires. I read this on the entry form for the Roar 2002 Electric Paved On-road Nats. Thanks in advance for any feed back.
Erik R. is offline   Reply With Quote
Old 07-24-2002, 08:00 AM   #2
Company Representative
Tres's Avatar
R/C Tech Charter Subscriber
Trader Rating: 14 (100%+)
Yes, it will work...
Works even better with HOT water......
It will clean the tire more than soften it....
Most use it for off-road....
Try some suntan lotion for traction compond also...
Hawaiian Tropic's®
Protection Plus SPF 15...
works very well.....
Tres is offline   Reply With Quote
Old 07-24-2002, 08:44 AM   #3
Regional Moderator
Darkseid's Avatar
I use it on my tires anytime I'm not getting the traction I want and I'm looking for consistent traction throughout the entire race, and not just the first two laps.
I'm not going to get into a debate about whether it softens or just cleans the tires. All I know is that my tires are quite sticky after I have wiped them down and the Simple Green dries.
Its a useful item to keep in your tool box. Between this and WD-40, their the only things I use on my tires.(if I use anything at all)
TLR 22...Tamiya F104...
Old 07-24-2002, 12:53 PM   #4
newracer's Avatar
I use it to clean my TC tires before every heat. I don't think it softens the tires, just cleans them so they are like new. I took an old BINGO marker, washed it out and put the simple green into it, it makes a nice applicator.
newracer is offline   Reply With Quote
Old 07-24-2002, 03:11 PM   #5
OSherman's Avatar
I have found similar results as Darhseid..
Another good practice is to give them a GOOD rub-down with SimpleGreen at the end of the race-day, then stor them in ziplock bags or tire tubes....The next time race-day comes around give them a feel...You will be happy with the results...
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 07-24-2002, 07:06 PM   #6
Erik R.'s Avatar
Thanks guys. I'm going to try what you guys suggested.
Do you normally use the Simple Green straight from the spray bottle or do you mix it with water before use?Thanks again.
Old 07-24-2002, 11:32 PM   #7
Boomer's Avatar
Send a message via ICQ to Boomer Send a message via AIM to Boomer
Eric,
I've seen it used straight and somewhat diluted, both. . .well, not at the same time, that would be kinda counterintuitive. . .ummm, never mind.
What I've mostly heard it used for is to clean the tires, then paragon or some such to treat the tires. . .
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 07-25-2002, 11:01 AM   #8
Regional Moderator
Darkseid's Avatar
See why I didn't want to get into whether it softens the tires or not? Everyone seems to have their own opinion about the matter.
anyways....
I use it at full strength. I put it in an old "BuggyGrip2" bottle because it fits in my toolbox well. I usually spray it onto a rag and wipe the tires down.
Man, if someone has to use SimpleGreen, then add MORE stuff, like Paragon, then they might consider that their using the wrong tires for the track!
Old 07-25-2002, 11:30 AM   #9
Boomer's Avatar
I don't even use the stuff, cept to clean things. . . strange concept I know. . . I do like the smell, though.
Old 07-25-2002, 02:37 PM   #10
Regional Moderator
Darkseid's Avatar
Boomer: I have a large spray bottle of the stuff and I don't think I have used any of it for cleaning yet!
Old 07-25-2002, 03:03 PM   #11
TigeRyan's Avatar
Send a message via AIM to TigeRyan
Is SimpleGreen something that can be found at Walmart or a super market???
TigeRyan is offline   Reply With Quote
Old 07-25-2002, 03:12 PM   #12
newracer's Avatar
yes, it is a general cleaner/degreaser. most of the time it can be found in the auto department
Old 07-26-2002, 01:36 AM   #13
Erik R.'s Avatar
Yeah, I got mine from Target.
Old 07-26-2002, 07:05 AM   #14
TigeRyan's Avatar
And you guys are saying it works better then the trinity stuff??? That is crazy, but I will try anything....worst case, I give it to the wife for cleaning
Old 07-27-2002, 07:33 AM   #15
Regional Moderator
Darkseid's Avatar
I don't know if it works better than Trinity or Paragon, but I know that it and wd-40 work great. And both of them are a hell of a lot cheaper than the "r/c" stuff.
Lower cost + good performance= great value!
WTB - simple TX+RX 27mhz Omarko Australia Wanted to Buy 1 06-22-2008 03:50 AM
Simple GFX 35 Question.. Deeds Electric On-Road 6 11-08-2005 08:27 PM
Simple Question Viper212 Rookie Zone 2 04-20-2005 06:34 AM
Simple Green Safe on Plastic? AE Racer Electric Off-Road 18 06-23-2004 12:14 PM
