Old 08-12-2002, 03:08 PM   #31
Fred Hubbard's Avatar
I don't recommend the simple green from my experiences with it, it takes a minimum a 1/2 to 3/4 of the first lap for the tires to come in / heat up. The WD40 takes a while to air dry, but here's the key, don't let it air dry. I normally put it on leaving it to sit for ~10 minutes, wipe of ~5 minutes before my race. The WD40 does not get sticky and I think this may be the key. I am only theorizing here, but maybe the reason why some of the other additives don't perform well and as consistent is because of they make the tire feel sticky. Maybe this sticky feeling of the tire contributes to the tire acting like fly paper and picking up a little more dust/dirt. Tires treated with WD40 are not sticky once you wipe it off. It could be that we automatically think that the tire has to be sticky in order to perform well, so we are always tstign for that sticky result on the tires. Food for thought...
Fred Hubbard
Fred Hubbard is offline   Reply With Quote
Old 08-12-2002, 06:39 PM   #32
That makes sence I will test stuff out at socal tuesday. I will stick with my pargon always
teamAE is offline   Reply With Quote
Old 08-12-2002, 07:06 PM   #33
I'm not implying to do away Paragon. Paragon is a tool, like a phillips head screwdriver. Just because you don't need to use the screwdriver at that very moment or for weeks at a time, you still keep it, because you know in the back of your mind one day you may need it. The same is true of Paragon. Cheers...
Fred Hubbard
Old 08-12-2002, 10:23 PM   #34
fatdoggy's Avatar
R/C Tech Charter Subscriber
How long do you guys let the WD40 soak into rubber tyres before your wipe them off, for carpet running?
Thanks.
fatdoggy is offline   Reply With Quote
Old 08-12-2002, 11:14 PM   #35
Team R's Avatar
Hi all--
Here is a little trick that I came across. Put your tires in a Zip Lock, than spraying some WD-40 into the bag. Seal up the bag and let them sit in the sun till just before you race. I was surprise at how hot the tires got the first time I did this. Give them a quick whip down, and you are ready to race.
I've been doing this for the last couple of races that I've gone to, and I have great traction for the whole race.
Let me know what you think???
Team R is offline   Reply With Quote
Old 08-13-2002, 12:08 PM   #36
kevink2's Avatar
Thanks.
At least 5 minutes or so, and then wipe off.
kevink2 is offline   Reply With Quote
Old 08-13-2002, 12:09 PM   #37
kevink2's Avatar
Originally posted by Team R
Hi all--
Yeah it works.
Old 08-13-2002, 01:28 PM   #38
tfrahm's Avatar
Send a message via AIM to tfrahm
I think you have hit on a key problem... Locally, our sedan racing is at the HobbyTown parking lot series. The parking lot is a totally unprepared concrete surface (they don't even sweep it). I have had to totally stop using ANY form of tire "sauce" -- every time i tried something, the tires would feel great in the pits (nice and sticky), but within 10-15 feet on the track, the car was on ice! When I examined the tires, I realized that what you said is exactly what was happening -- they would pick up all the dust and grit from the track (like a "lint roller") and lose traction. After 2-3 laps, they would seem to scrape that stuff off, but by then too much time had been lost.
As much as I like Simple Green (use it every week for OFFROAD tires in my tire scrubber), I have had to stop using it for sedan... Now my routine is to use a small wire brush to brush all the "crud" off the tires after a run and hand wipe them clean -- nothing more. This gives me a clean tire surface that is not "sticky" and I get a much better start to the race. unfortunately, this also means that I have one less "tuning" option (no tire "sauce" options)...
"If you cannot win, make the one ahead of you break the record."
Biff Racing Team #420 (Ah... The "good old days"...)
The local indoor Offroad Track: The RC Race Barn
TLR22-3.0, TLR22T-2.0, TLR22SCT-1.0
tfrahm is offline   Reply With Quote
Old 08-13-2002, 02:16 PM   #39
fatdoggy's Avatar
WTB - simple TX+RX 27mhz Omarko Australia Wanted to Buy 1 06-22-2008 03:50 AM
Simple GFX 35 Question.. Deeds Electric On-Road 6 11-08-2005 08:27 PM
Simple Question Viper212 Rookie Zone 2 04-20-2005 06:34 AM
Simple Green Safe on Plastic? AE Racer Electric Off-Road 18 06-23-2004 12:14 PM
