Old 07-31-2002, 09:34 AM   #16
Send a message via AIM to mrcrowbuster Send a message via Yahoo to mrcrowbuster
What does WD-40 do for tires? (Off and On-Road)
mrcrowbuster is offline   Reply With Quote
Old 07-31-2002, 09:40 AM   #17
TigeRyan's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to TigeRyan
Darkseid - et al,
Does the WD40 do anything to the CA on the tires, like loosing the bead at all? I put my rubber tires in ziplocks after cleaning them throughly with SimpleGreen, won't be racing for like 2 weeks so I want to make sure when I take the tires out I wont have to re-glue them before racing...
Thanks,
John
TigeRyan is offline   Reply With Quote
Old 07-31-2002, 01:46 PM   #18
OSherman's Avatar
Originally posted by TigeRyan
...I put my rubber tires in ziplocks after cleaning them throughly with SimpleGreen, won't be racing for like 2 weeks so I want to make sure when I take the tires out I wont have to re-glue them before racing..
You don't have to worry about the SimpleGreen harming the CA...that will never happen...but, it is always good to check the bead before EVERY trip to the track...
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 08-01-2002, 10:03 AM   #19
Boomer's Avatar
Send a message via ICQ to Boomer Send a message via AIM to Boomer
WD40 is mostly solvent. . .if you want to keep them in baggies for a long time with WD40. . .try it on some junkers first. I know Acetone will loosen CA given enough time (I use it to pull old tires off)
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 08-01-2002, 10:24 AM   #20
Fred Hubbard's Avatar
Believe it or not, WD40 works VERY well as an additive. Team AE and myself used it almost exclusively at the ROAR On-Road Nats this year. It worked very well compared to simple green. I can only speak from my experience, but when I used the simple green the car pushed for the first 1/2 to 3/4 of the first lap, but using the WD40 the car came right in. There was even a driver who wasn't using anything on his tires and had good traction, but when he used the WD40 he said the car was even better and the traction was consisent. His buddy used the WD40 and said he had too much traction, so he discontiued using it. Draw you own conclusions...
Fred Hubbard
Fred Hubbard is offline   Reply With Quote
Old 08-03-2002, 08:15 PM   #21
hyperformance's Avatar
Default wd-40?
i use simple-green alot, mostly to clean tires after heats & i put a little on them after race night, but, i use a traction compound as well. i seems to me the simple-green clears away the left-over traction stuff after a run. the compounds can build-up and make tires slick. i use the stuff full stregth & put it in an empty tration compound bottle (the ones with applicators built in).
i have never tried the wd-40 when and how do you guys apply it.
also, i run indoor carpet & occationally outdoor concrete & ashalt.
hyperformance is offline   Reply With Quote
Old 08-04-2002, 09:57 AM   #22
Fred -
Was that foams or rubber you were using WD40 on???
Thanks!
Old 08-04-2002, 05:54 PM   #23
It was rubber, Sorex 36R's to be exact. This was the handout tire for the Nats this year.
Fred Hubbard
Old 08-09-2002, 12:17 PM   #24
kevink2's Avatar
A 50-50 mix of WD-40 and NAPTHA make an excellent off road tire sauce, but not sure about on-road. The NAPTHA seems to help dry out the WD-40 after it's applied and subsequently wiped off. Don't smell it and don't smoke around this stuff though...
kevink2 is offline   Reply With Quote
Old 08-09-2002, 12:18 PM   #25
Boomer's Avatar
NAPALM????????
Old 08-10-2002, 05:11 PM   #26
skibum989's Avatar
naptha like in Ronsonol lighter fluid? that gives me an idea... has anybody tried lighter fluid as an additive?
skibum989 is offline   Reply With Quote
Old 08-10-2002, 05:50 PM   #27
Hi Guys
We have a series coming up where we have to run some rock hard kit type tires, what do you suggest doing to them to soften them considerably?
I dont just need a little bit of cleaning or softening, we need something pretty agressive.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 08-11-2002, 12:51 AM   #28
Boomer's Avatar
try soaking them in Paragon or similar traction compound. It should soften and recondition the tires. I've done it with old rubber and old old foam tires. . .
Old 08-12-2002, 12:05 PM   #29
kevink2's Avatar
Yeah, NAPTHA is the key ingredient in lighter fluid...helps dry up the WD-40 and penetrates the rubber.
Old 08-12-2002, 12:09 PM   #30
how long does wd-40 and simple green take to dry or when should I wipe it off? I tried them both and it loked like it took longer to dry but did feel sticky after a long drying
teamAE is offline   Reply With Quote
WTB - simple TX+RX 27mhz Omarko Australia Wanted to Buy 1 06-22-2008 03:50 AM
Simple GFX 35 Question.. Deeds Electric On-Road 6 11-08-2005 08:27 PM
Simple Question Viper212 Rookie Zone 2 04-20-2005 06:34 AM
Simple Green Safe on Plastic? AE Racer Electric Off-Road 18 06-23-2004 12:14 PM
