first battery... not too expensive.. which one? >
Old 10-16-2012, 06:53 PM
Default first battery... not too expensive.. which one?
Hi,
I am building my 10th scale (TC6.1) and am in the market for the battery. But don't know which one. I am not looking for super expensive ones but just to get me started.
Any suggestions..
Thanks in advance.
FourWheels is offline
Old 10-16-2012, 07:13 PM
rosko's Avatar
Crc 5300mah 40c.....i believe its 54.99
rosko is offline
Old 10-16-2012, 07:21 PM
bvoltz's Avatar
Trader Rating: 44 (100%+)
Great batteries: http://www.rc-battery.com/app/menu.p...e=Car%20Series
bvoltz is offline
Old 10-16-2012, 07:44 PM
I use the CRC batteries. Best bang for your buck hands down.
jayman24 is offline
Old 10-16-2012, 07:45 PM
Trader Rating: 3 (80%+)
+1 on the Gens Ace.
I was just as fast as the guys with their expensive packs
Get them from hobbyparts.com $32.04 ea. for 50c's and get free shipping when spending $50
76Trans Am is offline
Old 10-16-2012, 07:46 PM
Trader Rating: 27 (100%+)
Another vote for Gens Ace. Great batteries.
hyujmn is offline
Old 10-16-2012, 07:49 PM
B00t13g's Avatar
Thunder power or speed zone. I've used both and currently use thunder power in my on road cars.
B00t13g is offline
Old 10-16-2012, 07:57 PM
Trader Rating: 24 (100%+)
Another vote for Gens Ace and Hobbypartz.com.
Evoracer is offline
DARKSIDE's Avatar
what class and motor?
DARKSIDE is offline
Old 10-16-2012, 08:17 PM
gom
Also the Turnigy nano tech batteries are good stuff. you can get them from hobbyking.com
they are in the same price range as the GensAce.
gom is offline
Old 10-16-2012, 10:00 PM
Trader Rating: 21 (100%+)
Gens Ace or Turnigy Nano-Tech (not regular) in the 5000mah+ range are excellent packs
silencery is offline
Old 10-16-2012, 11:03 PM
Gens ace from www.hobbyparts.com. Stick with a 5000mah one, either 40c or 50c. It'll perform just fine for novice, scale spec, and 17.5. Make sure you're getting one of the ROAR-approved hard-case ones. The direct-wire 50c one is out of stock, so you'll have to settle for 40c or use bullets.
I tried a gens ace battery, and I'd probably still be using it if I hadn't blown it up. I connected the bullets backwards, heard a pop, and nothing would turn on. I thought it took out the ESC, but apparently there's a fuse or something in the battery that blew out. Much better to blow out a $35 battery than a $150 ESC.
EDIT: This one may also be worth considering, but it costs more and is only 25c:
http://www.amainhobbies.com/product_...5C-74V-5000mAh
-Mike
grippgoat is offline
Old 10-16-2012, 11:33 PM
VTA class for a 25.5 silver can motor.
-Mike
Ah great so gens ace it is. Sure will take a look, thanks for the link Mike.
Old 10-17-2012, 12:16 AM
-Mike
Its not a fuse, the tag from one of the cells blew off the tube. If you are very carefull you can split the case open and solder it back on but ONLY TRY THIS IF YOU ARE VERY COMPETENT OR HAVE GOOD INSURANCE
bucketboy is offline
Old 10-17-2012, 12:35 AM
jeff jenkins's Avatar
Trader Rating: 82 (100%+)
If you want a quality battery at a great price go to bmiracing.com they offer a 6500 mah 60c battery for normally $99 but for the month of October its $79.99 its an awesome battery and you can't beat the price .
jeff jenkins is offline
