Old 03-19-2005, 04:44 PM   #1
tandman's Avatar
Send a message via Yahoo to tandman
Default Ashphalt tires
Hey, I just want some opinions for ashphalt tires for an electric mod touring car. I will be racing on different tracks throughout the summer. My choices so far;sorex 28 & 32, CS-27's, Yokomo 138M or 139g2.
Which wheels are best and I will have to carry an assortement of inserts.
Any suggestions??
Dwayne Flodell
Team Mad Scientist
-When you need mad rip.....call the Mad Scientist
Team Sweepracing-R1 Wurks Team Canada
tandman is offline   Reply With Quote
Old 03-19-2005, 06:24 PM   #2
scoobydo's Avatar
Default Re: Ashphalt tires
Any suggestions??
I would stick with the CS-27's as they are they handout of choice at most races. (or is it the Take-Off's?) If you want to go with Sorex, the 28's would be good.
As far as inserts go, I like medium to medium soft.
The CS-27's or Take Off's have them pre mounted on dishes and come out much cheaper than building them yourself. Something like $8-9 bucks a tire which beats the $11-13 to build yourself.
scoobydo is offline   Reply With Quote
Old 03-19-2005, 06:32 PM   #3
Send a message via AIM to greencactus3
Default Re: Re: Ashphalt tires
they are takeoff cs27s i believe. and although they may be cheap, they are cheap rims. crack easily.(too easily ) and sumtimes the whole wheel breaks off the hub. otherwise they are great tires. just i dont recommend the wheels.
greencactus3 is offline   Reply With Quote
Old 03-19-2005, 09:22 PM   #4
murfy's Avatar
Trader Rating: 9 (92%+)
i think the cs 27s would be the go but i found that the sorex 28r's wear to much the must have a softer rubber thatn take off. i have had some success with the sorex 32r though and they don't ware as much but the only problem is you might need tyre warmers it it is too cold in the morning or night
Justin Murphy
Team Xray | Hudy | Hobbywing | Sanwa
murfy is offline   Reply With Quote
Old 03-19-2005, 09:33 PM   #5
tandman's Avatar
Default tires
Alright, thanks for the info!Looks like CS tires.
What about different temp ranges. CS-22, CS-27, CS-32???
Dwayne Flodell
Team Mad Scientist
Old 03-19-2005, 09:41 PM   #6
ChadCapece's Avatar
Where are you located in the world or US? And where are the track you will be racing at?
ChadCapece is offline   Reply With Quote
Old 03-19-2005, 09:50 PM   #7
tandman's Avatar
Default Pro4
I am up north in Canada. The track I will be racing on mostly is located in Edmonton,Alberta. Barry Baker was up here last year for the big race....Canadian Ashphalt Invitational...but it got rained out after the first day of qualy's.Look up the [email protected] edmontonrc.com
Dwayne Flodell
Team Mad Scientist
Old 03-19-2005, 10:37 PM   #8
murfy's Avatar
Default Re: tires
the 27 compound would be the safe bet with either medium or medium-hard compound insert.
if it is slightly hotter try the 32s but don't use any higher insert than a mediums.
Justin Murphy
Old 03-19-2005, 10:38 PM   #9
axel's Avatar
27 front 22 rear (take-0ff)
axel is offline   Reply With Quote
Old 03-19-2005, 10:48 PM   #10
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
Do NOT use different compounds at one time. Geez.
The CS 27s are good for over 60 degrees. Anything under use the 22s. Don't bother trying the 32s unless the track temp is over 140 and you are chewing the 27s up too quick.
As for the rims, I ran all last year including the NORRCA Nats and never broke the conter out of a wheel. In fact, I only cracked one wheel near the hub and I put some thick CA on it and sold the set to a novice racer. He ran it for weeks. If you're busting the centers out of them then you woulda busted any wheel. Just so happens you were running the Take Off tires.
CS 27s are the best bang for the buch and you will be VERY hard pressed to make another tire go faster and even if you do it will only be faster for one or two runs and even then only by hundredths of a second. That's after you've spent hundreds of dollars finding the majic combination.
BigDogRacing is offline   Reply With Quote
Old 03-20-2005, 12:05 AM   #11
axel's Avatar
Ok now i feel stupid. What's wrong with using different tire compound? One of the fast drivers at my place told me to.
Old 03-20-2005, 04:38 AM   #12
murfy's Avatar
generally you should run 1 compound all round. the different compounds help to get more/less grip front or rear
Justin Murphy
Old 03-20-2005, 08:45 AM   #13
tandman's Avatar
Default OK
CS-27's.....now what about traction compound? Can I use TQ orange outside? That is what I use indoor on carpet with Jaco foams.
Dwayne Flodell
Team Mad Scientist
Old 03-20-2005, 10:15 AM   #14
axel's Avatar
I used to run 27's all around, but when i mixed it up i felt my car was really hooking up.
Old 03-20-2005, 11:06 AM   #15
in the UK most people use CS22 but then again track temp dosnt normally exceed 35 degrees.
if hotter then that then definetly CS27 with fastrax yellows,or yokomo softs,works pretty well in hot conditions
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
trf racer is offline   Reply With Quote
Cleaning Out Garage Sale TIRES TIRES TIRES MattOCM R/C Items: For Sale/Trade 5 01-15-2008 03:55 PM
Ashphalt track design's stegger Electric On-Road 29 04-16-2007 09:43 AM
XRAY T1FK Ashphalt setup tandman Electric On-Road 4 03-13-2005 10:37 PM
TIRES tires TIres, Ellegi or UFRA. bleach1 Nitro On-Road 51 06-01-2004 10:58 PM
Used trc & jaco touring & 12th scale tires trued mint shape a ton of tires 1 to 3 run jason cheng R/C Items: For Sale/Trade 10 01-02-2004 10:27 AM
