Old 03-21-2005, 06:26 PM   #31
Default Interesting thread.....
I'm running on a track where from what I understand CS27's would be the way to go (I'm currently running Yokomo 138G in 540 stock and all seems good)...
Would running Sorex 36R cause to many problems you think as I'd like something that lasts a little longer?
The hottest temps around here still don't usually go above say 28'c....30 (air temp) on a really hot day.
Mabuchi540 is offline   Reply With Quote
Old 03-21-2005, 06:37 PM   #32
Send a message via AIM to greencactus3
do you want grip or do you want long lasting?
greencactus3 is offline   Reply With Quote
Old 03-21-2005, 06:39 PM   #33
Both would be nice
Just wondering how the harder tire might go given the same setup.
Old 03-21-2005, 07:42 PM   #34
ChadCapece's Avatar
You won't need setup changes if you change tires due to weather changes. But changing hardness on the same day will get loose if you go up in hardness and get tight if you go down
ChadCapece is offline   Reply With Quote
Old 03-21-2005, 07:52 PM   #35
Thanks for the info. Will stick with what works or it's equivalent then.
Old 03-24-2005, 07:49 AM   #36
BrainTeased's Avatar
while on the topic of tyres can i please ask how long would a set of take off 27's last in mod?
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 03-24-2005, 09:50 AM   #37
AdrianM's Avatar
With a 7x1 Orion motor in my car the first 4 runs on CS27's are basically identical in lap time. From runs 5 through 8 the tires slow down a tenth or two per lap. After that they fall off more and aren't worth practicing on anymore.
RP's last about half as long as CS tires but they are faster.
Sorex tires last one run and that it. They are 2-3/10ths slower per lap on the 2nd run.
This of course is in Florida with our brutal coral base asphalt. I hear out west Sorex last longer than around here. Asphalt out west is gravel/pebble based.
Adrian Martinez
Old 03-25-2005, 01:57 PM   #38
tandman's Avatar
Send a message via Yahoo to tandman
Default Tire life
Does using traction compound decrease the life of the tire?
Dwayne Flodell
Team Mad Scientist
-When you need mad rip.....call the Mad Scientist
Team Sweepracing-R1 Wurks Team Canada
tandman is offline   Reply With Quote
Old 03-25-2005, 05:22 PM   #39
thanks adrian. you say after 4 laps the cars fall of within lap times may i ask why? is it because of loss of foward traction? or does the car get very loose/twitchy towards the 9th run?
cheers in advance
Old 03-22-2006, 10:52 PM   #40
RAL
RAL's Avatar
Trader Rating: 60 (100%+)
Default Yokomo CS27
any one used the new Yokomo CS27? speedtech rc has them.
http://www.speedtechrc.com/store/ebp...id=355&id=5166
TEAM ARAI GRIP ● J★STYLE ● P1 BRAND ● RÄLDESIGNWERKS ● EXOTEK
RAL is offline   Reply With Quote
Old 03-23-2006, 04:38 AM   #41
protc3's Avatar
cheers in advance
i believe he means 4 race heats or battery packs run through the car.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 03-23-2006, 07:33 AM   #42
AdrianM's Avatar
With ALL tires when they wear the car start to push. Its subtle at first and some guys try to alter setups to get steering back but this is a waste of time. No matter what you do to your car it wont be as fast as it was during the first 4 runs on new tires.
Note that this is on asphalt. On carpet CS tires last FOREVER.
Adrian Martinez
Old 03-23-2006, 07:36 AM   #43
AdrianM's Avatar
The new Yokomo tires are C27 not CS27. They are not the same. This is Yokomo's attempt to cash in the massively popular CS27 name.
That said, Yokomo tires are usually pretty good.
If you want to try them SpeedtechRC.com will probably be the only place in North America to get them.
Adrian Martinez
Old 03-23-2006, 09:01 AM   #44
RAL
RAL's Avatar
yes thank you, I figured. I just wanted to know if anyone had used them yet and what their take on them was.
Cleaning Out Garage Sale TIRES TIRES TIRES MattOCM R/C Items: For Sale/Trade 5 01-15-2008 03:55 PM
Ashphalt track design's stegger Electric On-Road 29 04-16-2007 09:43 AM
XRAY T1FK Ashphalt setup tandman Electric On-Road 4 03-13-2005 10:37 PM
TIRES tires TIres, Ellegi or UFRA. bleach1 Nitro On-Road 51 06-01-2004 10:58 PM
Used trc & jaco touring & 12th scale tires trued mint shape a ton of tires 1 to 3 run jason cheng R/C Items: For Sale/Trade 10 01-02-2004 10:27 AM
