Old 08-19-2013, 12:59 AM   #181
Originally Posted by BadPanda818 View Post
finally assembled my kit and am I happy that I went with this kit. the driveline feels smoother than a newborns behind. Imagine the kit with acer bearings upgrade. Two thing I don't like about the kit; 1) aluminum screw stripped often during kit assembly. Mind you that I was using Hudy tools. 2) the piston on the shocks rubs a little on the cylinder. Is there any fix for this? besides the 2 mentioned deficiencies, the kit is well executed. comparing this kit to my Tamiya TA06 is not even worth mentioning just by weight alone. By the way, what rate springs come with the kit? I couldn't find any color marks anywhere on the springs. I wont be running the kit for a couple of weeks because of school stuff but I'm really looking forward into driving this kit. Great job Capricorn and keep up the good work.
Hi
I agree , what a fantastic car. I do not have had the problem you mention with the screws , they are titanium. The shocks work just fantastic , witch ones are you using , I have changed to the short big bore.
The normal kit springs , normal length are green and yellow
Xray T4 2014 / Orca VXX / Orca 5t
Team Xray-shop.dk
johnsen-dk is offline   Reply With Quote
Old 08-19-2013, 03:29 AM   #182
RC-Netshop.dk's Avatar
Hello Sir,
Great to hear you got the car assembled and are over all satisfied with it. Sorry to hear about the screws, next time you order some spare parts from me, I will included some extra screws. Please just remind me .
For the pistons scrubbing a bit, I have had the same problem with a piston. I just use very fine sandpaper, like corn 2000 and grind the piston very little. Then it's smooth and working excellent.
Please let me know if you need a god set-up. My driver Micheal Johnsen has done a lot of testing indoor/outdoor, Superstock/Modified and also tested all the hop-up parts, so he'll be glad to assist.
He replied you earlier, he is Johnsen-dk :-))...
All the best,
Niko
http://rc-netshop.dk/en/
Capricorn, REDS, CRC, Orcan, JP GIMAR, Ielasi Tuned, Tesla, JQ, Sanwa
RC-Netshop.dk is offline   Reply With Quote
Old 08-19-2013, 06:27 AM   #183
BadPanda818's Avatar
Trader Rating: 17 (100%+)
Originally Posted by johnsen-dk View Post
Hi
Originally Posted by RC-Netshop.dk View Post
Hello Sir,
All the best,
Niko
thanks for the replies. I couldn't find the color tabs on the springs to save my life. I've looked the entire spring and couldn't find it. the screw that it came with I think are aluminum screws. I have some spare titanium screws laying in my box and have replaced critical areas where I would need them. as far as the shock pistons, I filed the piston with 1.5k grit sandpaper until the exacto knife did stuck around the pistons. when I move the shaft around, I can feel the piston hitting the cylinder. maybe another o ring should fit. a general 17.5 non ramping set up would be nice but, I think the stock set up should be more than sufficient for 17.5. thanks again
Capricorn Lab TE-01 Orion R10 Pro, Orion VST2X 17.5, KO RSX One
Capricorn Lab TE-03 Orion R10.1, Fantom Ion V5, KO RSX One
Xray XB4 2017, Orion R10.1, Fantom FR-1 13.5, Protek 160T
Axial RR10 Bomber, MMP, Reline Pro4 4000Kv,Protek 150T
Futaba 4PKS R All sponsored by Visa
BadPanda818 is offline   Reply With Quote
Old 09-06-2013, 03:31 AM   #184
Finally completely finalized my car and here she is. This chassis looks so nice that I just want this for display.
Old 09-12-2013, 03:36 PM   #185
Ed Delgado's Avatar
Hi
I was told the screws are stainless steel and the turnbuckles steel as well.
Ed Delgado is offline   Reply With Quote
Old 10-26-2013, 06:40 AM   #186
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
Just wondering if anyone who has the flex motor mount could post the size of the layshaft bearings? Does the flex motor mount use the same bearings as the kit standard mount (5x10x4mm bearings).
Thanks in advance.
Leonard.
:::Smokem Racing:::RCMaker.com.au:::Speedy RC.com.au:::
"It's more fun to drive slow cars fast, than fast cars slow"...
DirtyDog3375 is offline   Reply With Quote
Old 10-26-2013, 01:58 PM   #187
Thanks in advance.
Leonard.
Hi Leonard
Yes , its the same size.
Let me know if you have other questions
Best regards
Michael Johnsen
Team Xray-shop.dk
Old 10-26-2013, 05:05 PM   #188
DS Motorsport's Avatar
If anyone is interested in picking up a barely used TE-01 let me know.
I'm currently cleaning mine to be sold.
Car comes with 3 chassis plates and has some option parts.
Will put up pictures when I finish building the car.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 10-26-2013, 05:29 PM   #189
Hi Leonard
Best regards
Michael Johnsen
Thanks heaps Michael.
Have you tried the new steering rack (with 8.5/9.5mm spacings) and how does it compare to the kit 10.5mm?
Old 10-27-2013, 12:21 AM   #190
Hi
Yes have tried it , but just in the 8,5 position , havn't had the time to test the difference.
The new shocks are on the way and will be tested quick monday evening and then off to round 1 of the ETS in Hrotovice.
Will return after next weekend.
Best regards
Michael
Team Xray-shop.dk
Old 11-04-2013, 10:18 AM   #191
Anyone got a TE02? no pics yet only renderings
PurcyP is offline   Reply With Quote
Old 11-04-2013, 11:21 AM   #192
Looking at the rendering. It looks like te01 with option parts with the exception of the chassis stiffner on the motor mount. I would get if it has the big bore shocks included
Old 11-04-2013, 12:39 PM   #193
hmm, might have to stick by yokomo and the bd7 then
Old 11-04-2013, 03:20 PM   #194
I highly recommend this car. Car performs better the more you drive it.
Old 11-04-2013, 03:29 PM   #195
you highly recommend the capricorn?
when you say the car performs better the more you drive it, does that mean its rubbish and you have to get used to it?
BATU PAHAT MBA CUP 2012 lawson Malaysian R/C Racers 83 04-30-2012 12:32 PM
JBRCC Warm Up Race 2012 Faiq-X4 Malaysian R/C Racers 37 03-12-2012 01:00 AM
MBA Cup batu pahat , johor lawson Malaysian R/C Racers 221 09-15-2011 10:02 AM
SEGAMAT RACE 2011(JBRCC ROUND 2) crazgt Malaysian R/C Racers 274 04-27-2011 09:39 PM
