Old 05-27-2013, 05:04 AM   #166
ali_g's Avatar
anyone started using the big bore shocks?
☆ JU.C RACING ☆
https://www.facebook.com/Ju.Cracing
ali_g is offline   Reply With Quote
Old 05-28-2013, 12:08 AM   #167
we've done a heap of testing over this last weekend with them and have found some good setups with them in stock and modified so far.
CPD Racing
chris_dono is offline   Reply With Quote
Old 05-28-2013, 01:33 AM   #168
ali_g's Avatar
what pistons do u recommend? are the optional o rings a must?
☆ JU.C RACING ☆
Old 05-28-2013, 01:27 PM   #169
either the 4 or 6 hole ones at the moment, optional o rings not required but they do make the shock smoother
CPD Racing
Old 05-29-2013, 12:16 AM   #170
ali_g's Avatar
are you guys running the capricorn springs or ride springs?
☆ JU.C RACING ☆
Old 05-30-2013, 11:53 PM   #171
Default New Parts
Hi
Just want to share pictures of the new big bore damper and new shock towers for the Titan Arc and Capricorn TE-01. Also the new 2 piece motor mount. All parts can you get from Rc-netshop.dk ,
just mail [email protected].
Capricorn 190mm EP-front-big-new.jpg   Capricorn 190mm EP-rear-big-new.jpg   Capricorn 190mm EP-motor-mount-new.jpg
Xray T4 2014 / Orca VXX / Orca 5t
Team Xray-shop.dk
johnsen-dk is offline   Reply With Quote
Old 05-31-2013, 04:05 AM   #172
chasingthepack's Avatar
hi chris,it was good to run along side you guys at amcc,marlon needs to find a better set up though,i think i was quicker,i managed to finally get my car handling that day
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 05-31-2013, 04:33 AM   #173
ali_g's Avatar
Originally Posted by johnsen-dk View Post
Hi
Hey Johnsen, care to share what springs are you using? Xray or Capricorn?
☆ JU.C RACING ☆
Old 05-31-2013, 07:34 AM   #174
Hi
I have used the optional capricorn springs , but only Got the Big bore on the car yesterday and tested around 120laps , Will be testing again tomorrow. Let you know. 4 holes and 600 csi in rear and 700 csi in front
Team Xray-shop.dk
Old 06-01-2013, 03:07 AM   #175
ali_g's Avatar
Hi
the progressive or normal springs?
☆ JU.C RACING ☆
Old 06-01-2013, 03:49 AM   #176
Progressive , cap 27037
Team Xray-shop.dk
Old 07-18-2013, 08:46 AM   #177
BadPanda818's Avatar
Trader Rating: 17 (100%+)
Finally about to get one. Does anyone know the difference between the ISE and regular version? Thanks
Capricorn Lab TE-01 Orion R10 Pro, Orion VST2X 17.5, KO RSX One
Capricorn Lab TE-03 Orion R10.1, Fantom Ion V5, KO RSX One
Xray XB4 2017, Orion R10.1, Fantom FR-1 13.5, Protek 160T
Axial RR10 Bomber, MMP, Reline Pro4 4000Kv,Protek 150T
Futaba 4PKS R All sponsored by Visa
BadPanda818 is offline   Reply With Quote
Old 08-02-2013, 09:49 AM   #178
Finally bought it. Anyone can share an asphalt setup medium track and medium traction. Also can you use arc r10 parts as a last resort if parts do not come in in time? Thanks
Old 08-02-2013, 10:38 AM   #179
Trader Rating: 30 (97%+)
just wondering except for the red aluminum, what else is different about this car, from the arc r10 2013, which costs less, about 175 less with shipping, so confused,
zaraz is offline   Reply With Quote
Old 08-18-2013, 11:53 PM   #180
Default great kit
finally assembled my kit and am I happy that I went with this kit. the driveline feels smoother than a newborns behind. Imagine the kit with acer bearings upgrade. Two thing I don't like about the kit; 1) aluminum screw stripped often during kit assembly. Mind you that I was using Hudy tools. 2) the piston on the shocks rubs a little on the cylinder. Is there any fix for this? besides the 2 mentioned deficiencies, the kit is well executed. comparing this kit to my Tamiya TA06 is not even worth mentioning just by weight alone. By the way, what rate springs come with the kit? I couldn't find any color marks anywhere on the springs. I wont be running the kit for a couple of weeks because of school stuff but I'm really looking forward into driving this kit. Great job Capricorn and keep up the good work.
BATU PAHAT MBA CUP 2012 lawson Malaysian R/C Racers 83 04-30-2012 12:32 PM
JBRCC Warm Up Race 2012 Faiq-X4 Malaysian R/C Racers 37 03-12-2012 01:00 AM
MBA Cup batu pahat , johor lawson Malaysian R/C Racers 221 09-15-2011 10:02 AM
SEGAMAT RACE 2011(JBRCC ROUND 2) crazgt Malaysian R/C Racers 274 04-27-2011 09:39 PM
