Old 12-17-2012, 05:19 AM   #136
chicky03's Avatar
Send a message via AIM to chicky03
Originally Posted by gsxr0311 View Post
i doubt it, but i hope so. a few friends of mine who drive the nitro car called them and asked them if they had thought about carrying this car and they said no. it a shame though because it is a good brand and im sure more people would drive this car if amain had parts in stock. i know of at least 8 people around here who have the nitro car and we all need parts.
You can order the parts from here, www.desotoracing.com
If you are having trouble finding parts email me, [email protected]
I will also be able to direct you to US dealers that will be stocking the electric car.
Serpent America, Picco, Desoto Racing, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa, Amain Hobbies, MIP, Getcustomized, EZ Customs
chicky03 is offline   Reply With Quote
Old 12-17-2012, 08:03 AM   #137
DS Motorsport's Avatar
Originally Posted by rc carnage View Post
hi all
can anyone tell me the internal drive ratio is ???
and if the ep190 can run 48 pitch as i have to run on an outdoor track
thanks jt
Internal ratio is 2.0
Running 48 pitch gears isn't a problem. The maximum amount of teeth you can fit is 110 in total with 48 pitch, so a 32 pinion and 78 spur for example.
I would recommend using the RW or the Xray spurs, these fit perfectly.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 12-17-2012, 09:55 PM   #138
rc carnage's Avatar
Thanks DS for that
I will look at the xray parts
Also does the xray ep diff fit the Capricorn ep190
Thanks jt
rc carnage is offline   Reply With Quote
Old 12-17-2012, 10:45 PM   #139
rc carnage's Avatar
Would this be for stock 17.5 or modified 32pinion 78 spur
Thanks jt
Old 12-18-2012, 01:58 AM   #140
Thanks jt
That's 'close' to stock settings. Probably want to go a bit smaller on the pinion depending on motor/esc settings.
Regards,
Simon
Team_Krusty is offline   Reply With Quote
Old 12-18-2012, 03:43 AM   #141
Thanks DS for that
Thanks jt
This is for a 13.5T motor and blinky esc.
Don't know whether the Xray diff wil fit, the internal ratio for the Xray is different so maybe the amount of teeth on the diff is also different?.
If you have measurements for the diff (space between the bearings) I could check if it will fit between the Capricorn's bulkheads.
The Capricorn geardiff is really good btw, very smooth because of the Teflon enhanced Kevlar material.
P1-RC.com
Old 12-18-2012, 06:20 AM   #142
Bishop's Avatar
Thanks jt
As an example, my Photon also runs a 2.0 internal ratio, running 17.5 blinky at the Qlds I went up to a 66/40T combo by end of the event, kind of extreme, but there you go.
Spur to pinion ratios are also one of those things you never quite know till you can fit some and see, as even if cars share the same internal ratio, they often space the spur to pinion gap differently, meaning without a supplied gearing example chart, your guessing till you can fit something and see what fits.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 12-18-2012, 06:41 AM   #143
Before I drove the TE-01 I was running the Awesomatix, this had a very nice way of mounting the battery in the car, removing the need for battery tape.
Since I don't really like the tape mounting method I had some parts 3d printed:
Everything fits perfectly and I will test it on the track tomorrow.
P1-RC.com
Old 12-18-2012, 02:05 PM   #144
303slowdown's Avatar
Trader Rating: 24 (100%+)
Your car stand is sweet
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 12-18-2012, 02:07 PM   #145
Trader Rating: 15 (100%+)
Yes, I want that car stand. Might even be cooler than the carbon pit board that Sam and I were drooling over at IIC.
DS Motorsport: Did you make or purchase your car stand?
Chris Hillier | 5280 Raceway | www.5280raceway.com | Racing. Elevated.
Destiny | LRP America | Protoform | Xenon/JFT | Gravity RC | Motiv | Sanwa | Max.FX
LloydLoar is offline   Reply With Quote
Old 12-18-2012, 02:25 PM   #146
It's a standard aluminium car stand but wrapped with 3M carbon vinyl.
P1-RC.com
Old 12-29-2012, 09:13 PM   #147
rc carnage's Avatar
if this is for 13.5 blinky, what would you suggestion be for modified 4turn??
and also is there a roll out i should be close to
example ( 20pinion 84 spur will give me 8.4fdr and a roll out of 23.56)
is there an optimum roll out i should be looking for ???
thanks
Old 12-30-2012, 03:37 PM   #148
Chickentrader's Avatar
http://chickentrading.com/viewtopic....9&p=8352#p8352
thanks
My rollout calculations differred from yours; John? http://chickentrading.com/viewtopic....9&p=8352#p8352 I have fixed the problem.
Kindest regards,
Lars.
Support your local RC stores - they support our sport!
Social media The empowerment of the small individual to enforce democratic process at the expense of dishonesty.
Chickentrader is offline   Reply With Quote
Old 01-03-2013, 11:28 AM   #149
gsxr0311's Avatar
Trader Rating: 19 (100%+)
any new results for this car, are people happy with it?
Special Thanks to: RC Target, Ko Propo USA, A Main Hobbies-SWORKz USA, R1 Wurks, and Absolute Hobbies.
Capricorn: LAB-C802, LAB E801, LAB-C03, TE03, and P01 235mm. IGT8. SWORKz: S350BK1 EVO II, S104EVO, S12-1M. Top Rebel 12.
gsxr0311 is offline   Reply With Quote
Old 01-03-2013, 06:21 PM   #150
At my hometrack we have 3 TE-01's running and all 3 drivers have been very happy with their cars. The precise fit is still there and no visible wear on any of the parts. The car also seems to be really strong, one of the guys had a faulty steering servo which sometimes didn't came back to center. This caused him to hit the boarding pretty hard, put no broken parts. The only thing which can happen when you hit the boards, and you don't use a servo saver, it can cause the servo mount to move a bit so the car will pull to one side. However when you change the standard screws for some high quality (12,9) steel screws you can tighten the mount a lot harder and the issue disappears.
Or you can use a servo saver of course when you hit the boards several times during a run.
I previously ran the Awesomatix and at the first race with the TE-01 I improved my personal best by 1 tenth. This currently is also the fastest time set during a race.
One of the other guys improved his personal best by 7 tenths, he moved up from a low a-main finisher to a podium contender.
Several experienced drivers, previous ets winners, also tested the car and all have been very positive about the car's handling. One of them improved his personal best within the first battery he tried my car!.
P1-RC.com
BATU PAHAT MBA CUP 2012 lawson Malaysian R/C Racers 83 04-30-2012 12:32 PM
JBRCC Warm Up Race 2012 Faiq-X4 Malaysian R/C Racers 37 03-12-2012 01:00 AM
MBA Cup batu pahat , johor lawson Malaysian R/C Racers 221 09-15-2011 10:02 AM
SEGAMAT RACE 2011(JBRCC ROUND 2) crazgt Malaysian R/C Racers 274 04-27-2011 09:39 PM
