Just got a new Gens Ace 6s 5300mah 60c pack... High internal resistance? >
Old 09-29-2012, 10:27 PM
Default Just got a new Gens Ace 6s 5300mah 60c pack... High internal resistance?
I just received a new 6s 5300mah 60c pack from hobbypartz.com. I put it on my icharger to read the internal resistance, and got the following readings per cell (in mohms)
5 3 9
5 4 2
This is before the initial charge. It's sitting at storage voltage as of right now - and all the cells are exactly 3.84 volts.
According to everything I've read, these IR numbers are quite high. The application that I'm using this battery for is going to really, really stress it.
Anyone have an opinion?
DudeInMyrtleBch is offline
Old 09-30-2012, 01:11 AM
I guessing but not sure but I think those lipos are 2s2p configuration which will have higher IR than a pack that 2s1p. There are threads regarding the differences between the two.
trigger is offline
Old 09-30-2012, 01:13 AM
My bad, just read that you are discussing 6s.
trigger is offline
