Nosram pure 13.5T
Nosram pure 13.5T
Hi,
That's my first post and I have very small experience on RC cars.
I bought a used xray T3 and it came with a nosram pearl racing ESC and an old 10.5T nosram motor. After driving a few times I replaced the old motor with a new nosram pure 13.5T. After 4 minutes of driving the car, the new motor died... The gearing is exactly the same as I had with the previous motor, the same battery and I haven't changed the ESC settings.
After coming back home I realised there is an extra rotor supplied with the motor because some rotors had quality issues leading to quick discharging.
Is that a common issue with nosram motors? Is the motor going to be OK if I replace the rotor??
Hi,
To be honest, I saw there was a spare rotor in the box. But didn't read the note...
Now, I took the old rotor out BUT when I try to fit the new one I can't close the can of the motor! I am not sure whether the end of the rotor is in the bearing or not. Any tips on that??
Maybe the new rotor needs different shimming tolerances... Try to mount it without shims first.....
The problem was that I was trying to fit the rotor without removing the sensor first.
After removing the sensor it was much easier to fit the rotor in the bearing.
It looks like the motor works again with the new rotor. But I have to try it at our local track. Hopefully I haven't damaged it when running it with the old rotor.
Do be honest I am quite dissapointed that the new motor was delivered with a faulty rotor. If NOSRAM knew that there was a batch of faulty rotors, they should have replaced them themselves...
