Rc wont run and beeps but the wheels turn. >
Old 09-26-2012, 08:37 PM
Default Rc wont run and beeps but the wheels turn.
When I turn it on all it does is flash, beep and wont move. However when I try to turn the wheels, they do. Just the way they should. It just wont move forward or backwards. Should i just get a new esc? The ESC i have is a TEU 101BK. I have tried to reset it, doesnt work. I have made sure all the wires are plugged in correctly
tashg350z is offline
Old 09-27-2012, 04:38 AM
Norman2's Avatar
Hi, Did you check the throttle trim on your transmitter?
Regards
Norman2
Norman2 is offline
Old 09-27-2012, 04:47 AM
Kinda sounds like what happens when I run a different car and I forget to change model number on my remote. It will beep when turning on the ESC and the tires will turn but doesn't make the second set of beeps when it recognizes the remote so throttle won't work untill I change model #
Not fimiliar with that ESC but try re-binding your remote and Reciever.
Voltron989 is offline
SteveM's Avatar
Trader Rating: 160 (100%+)
Try the servo reverse on the transmitter for the throttle and then reset the ESC.
SteveM is offline
Old 09-27-2012, 05:34 AM
sosidge's Avatar
The Tamiya 101 speedo beeps if it is getting no radio signal. So double check the wiring in the car and the batteries/settings in your transmitter.
sosidge is offline
