Old 03-16-2005, 09:04 PM   #1
Registered User
RC Noob's Avatar
Send a message via AIM to RC Noob Send a message via MSN to RC Noob
Default charger question
http://www2.towerhobbies.com/cgi-bin...?&I=LXXG87&P=7
im using that charger, and im hoping to get a power supply, if i can convice my dad, so i can charge my batteries a bit faster. (it only charges at 3.5A)
i want to use this power supply
http://www.buyreliant.com/psupplies/psv200.htm
will it work?
RC Noob is offline   Reply With Quote
Old 03-16-2005, 09:39 PM   #2
vtl1180ny's Avatar
R/C Tech Charter Subscriber
Yes.... It puts out 20 amps, perfectly fine... You could run 3 chargers on that....
I still lurk....
vtl1180ny is offline   Reply With Quote
Old 03-16-2005, 09:47 PM   #3
dakrat's Avatar
whats up with multiple posts on same topic?
dakrat is offline   Reply With Quote
Old 03-16-2005, 10:00 PM   #4
Still Bill's Avatar
Default Re: charger question
Originally posted by RC Noob
http://www2.towerhobbies.com/cgi-bin...?&I=LXXG87&P=7 will it work?
Regardless of the input power, this charger will only charge each battery at a maximum of 3.5A.
You won't gain anything by using a power supply instead of the standard 120V connection.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 03-17-2005, 12:10 AM   #5
Entropy's Avatar
He's just a noob, go easy on him...
Entropy is offline   Reply With Quote
Old 03-17-2005, 07:48 AM   #6
Still Bill's Avatar
Uhhhhhhh...I thought I was...Because his stated goal is to "charge my batteries a bit faster".
Old 03-17-2005, 08:14 AM   #7
Registered User
RC Noob's Avatar
hmm damnit, so it wouldnt work?
Bill- he was talkin to dakrat not u
Old 03-17-2005, 04:04 PM   #8
Registered User
RC Noob's Avatar
o yeh, one question, why wouldnt it work?
Old 03-17-2005, 10:01 PM   #9
Still Bill's Avatar
Oops! He, he...
The spec sheet you attached indicates that this charger is only rated to charge at a maximum ampherage of 3.5 amps for each battery being charged. If you have the charger plugged directly into an 120V AC outlet or powered by a separate 12V DC power supply, you still only get the maximum ampherage that the charger is rated at...being 3.5 amps.
Charging at 3.5 amps is not a bad thing if you are just bashing or playing around. For racing at a track in competition, you would want a higher end charger rated with a maximum of at least 6 amps.
The fact that your charger will charge two battery packs at the same time is pretty cool though.
Charger Question Evilstealth Electric On-Road 1 01-29-2007 03:29 AM
charger question peanutbrains Nitro On-Road 9 08-22-2005 09:34 AM
Charger question RedBullRacin Rookie Zone 5 01-16-2004 01:36 AM
indi charger question/3300mhz battery question TT_Vert Electric Off-Road 4 12-27-2003 12:46 PM
Charger Question Motorsports00 Australian Racing 33 10-13-2003 01:14 AM
