Hobbywing 1S 2.0 ESC NO PUNCH! >
Old 09-21-2012, 11:17 AM
DesertRat's Avatar
Default Hobbywing 1S 2.0 ESC NO PUNCH!
I have a hobbywing 1s that I am running in 1s 17.5 blinky pan car, and it has no punch. I swapped it for my Stock Spec V2, and it has great bottom ed punch for the same motor and gears. I turned its punch control up as far as it would go and it made no difference, still accelerates like a dog. The ESC is going to full throttle, and has good top-end, and I don't know what the fix is, does a software update put some more punch into the thing?
DesertRat is offline
Old 09-21-2012, 12:00 PM
Trader Rating: 27 (100%+)
Run better batteries? Hobbywing does state that you need high quality batteries with high C ratings.
hyujmn is offline
Old 09-21-2012, 12:45 PM
Trader Rating: 20 (100%+)
could the problem be that you are running 17.5 blinky 12th scale....?
LloydLoar is offline
Old 09-21-2012, 01:10 PM
Need alittle more info... Could you post your HW ESC setup, Rollout and Motor type.
Cheers,
Shawn
Shawn68z is offline
Old 09-21-2012, 02:21 PM
DesertRat's Avatar
Cheers,
Shawn
Okay, all of my boost/turbo is set to zero, with everything else set to their default settings. My punch control I turned all the way up but it made no difference, so I turned it down to the default. my motor is a RevTech 17.5 at about 93 mm of rollout, I run a CRC 60c battery.
Old 09-21-2012, 02:36 PM
NolanP's Avatar
I know its annoying but please post exact settings for every parameter if you would like us to help you.
NolanP is offline
Old 09-21-2012, 03:19 PM
DesertRat's Avatar
Okay, no problem:
Running Mode: forward/brake
Cutoff: 3v/cell
Start Mode: Level 6
Max Brake; 75%
Initial Brake: 0
Neutral: Narrow
Boost Timing: 0 / 00
Turbo Timing: OFF
Boost Start RPM: 15000
Turbo Delay: 0.8s
Timing Punch: 1000 (default)
Maybe I should download the V2.1 software, I have the link...
Old 09-21-2012, 08:02 PM
I am not to familar with the Stock Spec, but are you running it in Blinky Mode? Or are you using boost?
Also, what version of HW Firmware are you running. I think you need to turn up your timing on your motor alittle, and check the temps. I found when running the HW, I had to reduce my rollout abit (4-6mm), and increase my motor timing about 10 degrees.
Shawn
Shawn68z is offline
Old 09-22-2012, 01:55 AM
sosidge's Avatar
Okay, no problem:
Cutoff: 3v/cell
Start Mode: Level 6
Max Brake; 75%
Initial Brake: 0
Neutral: Narrow
Turbo Timing: OFF
Turbo Delay: 0.8s
If you are running in blinky class, you should be running the blinky software (508) which means you need to hook the ESC up to the PC.
For start mode (punch), that should be at the maximum setting (9). Judging from what I read between the lines in the HObbywing thread, you should NEVER run the punch at less than 7 because the software might have a very soft delay on it.
Having said that - if you like your blinky LRP better, why not stick with it? I've done a lot of running with the blinky HW in TC and the brakes are not correct, they have a softness that causes issues on heavy-braking tracks.
sosidge is offline
Old 09-22-2012, 11:54 PM
DesertRat's Avatar
I like the Stock Spec, but it's in my mod car.... it's a it's-running-good-don't-break-the-seal sort of situation,
I downloaded the 508 software, so hopefully it will be better now.
Old 09-23-2012, 01:29 AM
Thanks for all the reports guys, nice to hear that.
caaraa is offline
