Xray T4 '13
#1366
Well, I run 64p gears. Only takes less than a millimeter of the motor shifting to ruin a spur. Maybe I should put friction washers under the screws that hold the motor. I can send you a pic of the flat spot on them if you still can't believe it. I'm not a hack either, I'm not Paul Lemeiux but I'm being racing R/C's since 1984. That's the only part I've had to replace on this car. Everything else is solid in this car, believe me I think this is definitely their best work yet. This doesn't mean there's not room for improvement to make it better. I already sent my observations and suggestions to Xray on this matter.
#1367
The motor moved.
#1368
I am debating on picking one of these cars up but my local shop doesn't really stock this car very much. From what I am reading it looks like I should have a couple rear hubs on hand along with front C Hubs as well. Any other recommendations?
Would anyone recommend getting aluminum front C hubs?
#1370
#1371
#1372
#1373
Are you using a thin shim or washer behind the motor screws? There is nothing different between this car or a lot others that just use the bottom screws to mount the motor. If you are not using a washer or shim, try that. Or is it possible the mounting hole on the motor have stripped and worn, or the screws are too short? Just throwing some thing out there.
As far as parts, knuckles. The T4 is my 4th xray car. I have broken one knuckle ever, and I am a horrible driver, but I have had to replace them due to the hole stripping for the camber link. Also, if your ECS or CVD decides to blow up, it will tear a knuckle up real good. Depending on what you are running motor wise, I would consider upgrading the spool out drives. Also, the 3.5mm blades wear out quickly.
#1375
With my first T3'12, I sheared off an aluminum turnbuckle, broke a rear hub, bent a hinge pin and broke a plastic suspension mount, from just one very nasty hit where I swung a bit wide coming out of a corner onto the straight and caught an outside board where they joined together. A board was sticking out just enough to grab my rear tire and rip it completely off. My second T3'12, I never broke anything on it and I raced it more often than the first one. The first one I use for mod, the second I used for 17.5 boosted and 17.5 blinky. I have tons of spares, almost enough to make another car, but I never need them. I prefer to be prepared, just in case, but it takes a lot of force to break anything.
#1376
The other thing with any Xray car, parts tend to go on back order. Especially knuckles (hard), hubs and arms.
#1377
Have you checked to see if the screws in the kit are bottoming out in the motor, not against the motor mount?
I ask as when I was building my kit, the screws seemed very long, so I tried them in motor when out of the car (screwing them in gently until the fouled on something) and measured between the can and the screw head, then measured the width of the bulkhead head. My screws are 0.1mm away from bottoming out inside the motor can.
Was just thinking that perhaps if they are bottoming out sooner than mine, you might be tightening them into the motor can, not against the mount.
I's using washers behind my screws now to make sure (and spread the load to prevent what you've described)
I'm not saying this was definitely the problem you encountered, but something worth checking
#1378
I noticed the supplied screws seem long too. Anyway I used my own stainless steel screws I believe the size is m3x8mm I thInk . Is the same button head type and everything. Believe me they were tight, but I did not put washers underneath. I'll try that and put some friction washers to minimized it happening again.
#1379
I noticed the supplied screws seem long too. Anyway I used my own stainless steel screws I believe the size is m3x10mm I think . Is the same button head type and everything. Believe me they were tight, but I did not put washers underneath. I'll try that and put some friction washers to minimized it happening again.
#1380
I'm sure in mod every little bit helps. Did you run ecs' when you were running 17.5? I'm just curious if you notice the difference as much in a slower class? Also, you and I are the only ones running P37's, anybody ever tell you that you are crazy for running this body? Everyone seems to think its the worst body out there.
I know racers who run the regular drive shafts in mod because they bind up and help to slow the car down, around here you will see everyone running fast in spec classes run ecs because the drivetrain runs smoother. The car just feels better at full lock with them, I have been running the spec r v2s lately and they are holding up the best for me, I did change the pins though, the stock ones are not great.
Anyway, too bad no one has a pair to test so I'll probably end up buying a pair. Not sure if I'd go with the Xray ones or the Spec R V2's?
