Xray T4 '13
Old 10-29-2012, 12:46 PM
  #1201
Skiddins's Avatar
Originally Posted by CoreyW. View Post
Well, yet another successful weekend for the T4! We were able to TQ and finish 2nd at the Halloween classic against a small but stout field -Keven Hebert, Josh Cyrul, Ray Darroch, Andrew Knapp to name a few. The car only needed a few tweaks from the setup we have been playing with since IIC. During the weekend, we had a tenth quicker hot lap(consistently I might add) than Keven and Andrew qualified almost 4 seconds ahead of him. This was especially exciting given the fact that Kevin was the only person really giving Ronald Volker a hard time at the IIC. The final was a fantastic race, both almost bumper to bumper for the entire 6 minute up until the final set of corners where Andrew made a last ditched effort to get by after an earlier bobble. Kevin is incredibly good out front and probably the hardest person to pass in RC As they came around the sweeper onto the straight they were side by side and they touched, as a result both needed to be marshalled. Andrew was marshalled a little quicker and therefore could have driven away for the win but he decided to stay put and let Kevin go across the line first. Andrew knew he forced the issue and decided it was not the way he wanted to win - a great move in the eyes of most. Despite losing the main, it was a great weekend and we learned even more about the new car and what it needs to be a legitimate contender.
One thing that I found very interesting was during the prep for the main. I noticed that I had not installed any screws to hold the spool cups securely to the spool itself(we all make mistakes right? )so like a good mechanic, I corrected my "mistake" and installed the screws. Up until the main, every round we had been clear of Keven by a tenth allowing Andrew to control the pace, but for some strange reason we lost that tenth in the main. We went from 9.2 to 9.3 and this small difference allowed Keven(he was also doing 9.3's) to pressure Andrew right from the start. After a debrief with Andrew, he informed me that the car was a little more "edgy" but other than that the car was almost identical to the runs previous. So now I have a suspicion that maybe the screws vs. no screws in the spool had something to do with it. Have I stumbled across something here? Unfortunately, I will have to wait till the weekend to test this but I thought I would throw it out there for people to discuss.
What does he find the difference to be between the outer camber link position and the middle position?
Skiddins is offline
Old 10-29-2012, 12:52 PM
  #1202
Originally Posted by Skiddins View Post
Or perhaps trying a couple of thick rubber O-rings behind the outdrives and screwed in?
I do not think that would work like well as it would bind up the shafts especially since we run 52mm. I have been thinking about this allot and I feel it has something to do with the cups moving freely along with the shafts causing less bind when turning or when weight tranfers front to rear. The movement is little but it could be just enough to make a difference.
We will know after the test I guess.
CoreyW. is offline
Old 10-29-2012, 12:53 PM
  #1203
Front or rear? And are you referring to the inside camber link positions?
CoreyW. is offline
Old 10-29-2012, 01:05 PM
  #1204
Skiddins's Avatar
Yes, sorry, the inner upper link positions and their effect at either end.
Skiddins is offline
Old 10-29-2012, 03:37 PM
  #1205
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
andrewdoherty is offline
Old 10-29-2012, 07:41 PM
  #1206
erchn's Avatar
Originally Posted by andrewdoherty View Post
Not sure why you would erase this, but I agree, plastic spool cups aren't great. I run the side piece racing cups with blades and they are great.
erchn is offline
Old 10-29-2012, 07:51 PM
  #1207
jlfx car audio's Avatar
Trader Rating: 37 (100%+)
After a few race days I'm sure the plastic spool cups get a small grove inside them where the bone rides . And I would figure it would torque the drive and try to pull the bone into the grove . With my old top car we would put a new set on every race day ... they were cheap and soft tho have no clue about the X-ray cups
jlfx car audio is offline
Old 10-29-2012, 08:17 PM
  #1208
haywood's Avatar
Trader Rating: 49 (100%+)
I don't like dnf's! That's why I run Nikita's!
haywood is offline
Old 10-29-2012, 08:18 PM
  #1209
Trader Rating: 15 (100%+)
Default Spool cups
How about using 2 mm longer screws that will bottom out against each other inside the spool and allow 2mm of movement by the spool cups . Could be risky since the flat spots that are on the spool cups are about 3mm .
AARON YOUNG is offline
Old 10-29-2012, 08:30 PM
  #1210
What's wrong with the xray steel out drives? Well other than price I'm sure...
Old 10-29-2012, 08:37 PM
  #1211
erchn's Avatar
Nothing, but in modified the blades wear out very quickly. The Nikita's are the same diameter as the blades so they are excellent.
erchn is offline
Old 10-29-2012, 08:42 PM
  #1212
veecee's Avatar
Trader Rating: 34 (100%+)
Were you running DCJ's?
veecee is offline
Old 10-29-2012, 08:51 PM
  #1213
Not sure what u mean . Do they not use blades ?
Old 10-29-2012, 09:23 PM
  #1214
Lightbulb
The Nikita's use blades but contact point with the
blades have a bigger surface area. The blades and
outdrives last longer.
RCing15 is offline
Old 10-29-2012, 09:40 PM
  #1215
Got ya..
