Xray T4 '13
Old 10-20-2012, 06:46 PM
  #871
Originally Posted by Miniripper View Post
Here you go.
Miniripper, where can a get some the tire holder compartments you have on your bench?? I must say they are pretty cool..
Pinionizer is offline
Old 10-20-2012, 08:04 PM
  #872
RCknight's Avatar
Wow not much mention of the new shocks. After years of people requesting new shocks how are they? Are they the bomb or what? how do they compare to the Tamiyas?`
RCknight is offline
Old 10-20-2012, 08:11 PM
  #873
Dude, what servo did you install? I have a brand new Savox 1257TG which couldn't fit as the body was excessively rubbing the servo saver arm (302526) It was way too tall. Beware of tall servos (the height from the ears to top of the body, hope you guys get what I mean). So I reluctantly installed a faithful 1251MG low profile unit.
I would really like to know of other servo options for this fabulous kit. Thanks!
cheapskate.brok is offline
Old 10-20-2012, 09:11 PM
  #874
RCknight's Avatar
Anyone still make sell chassis plate jig for the Xray?
RCknight is offline
Old 10-21-2012, 02:42 AM
  #875
Skiddins's Avatar
I managed to get about 50% rebound when building straight out of the packet.
They go together easily. Also seems like the edges of the bladders are slightly thicker (the point screwing the cap on between the cap first touching the bladder and the cap being tight has greatly reduced) and I think the cap has limited travel so it's harder to pinch the bladder.
Can't remember what Tamiya shocks are like as I haven't used a set in years but these latest Xray shocks are simple to build and appear to be very smooth once built.
I did notice that the pistons seemed to be almost slightly undersized when first put together.
I'm assuming that after spending some time soaking in the oil that they expand slightly.
Skiddins
Skiddins is offline
Old 10-21-2012, 03:24 AM
  #876
I got them from www.mmr-flux.co.uk
Miniripper is offline
Old 10-21-2012, 10:31 AM
  #877
what size 64p spur gears are you guys putting in? I prefer 64p as i run carpet only.
rescue119 is offline
Old 10-21-2012, 11:48 AM
  #878
Trader Rating: 14 (100%+)
For 17.5 and 13.6 I use 96 t.
trigger is offline
Old 10-21-2012, 12:14 PM
  #879
bvoltz's Avatar
Trader Rating: 44 (100%+)
When do you use the Graphite, Extra Hard vs Hard arms?
bvoltz is offline
Old 10-21-2012, 12:25 PM
  #880
morgoth's Avatar
Drove my T4 today at our club race. All I can say is that it's an awesome car. Comming from a T3 2011 with 2012 chassis and topdeck, this car was faster for me.
It's was more stable, easy to drive and had plenty of steering The track I drove on was low - med traction. We drove with ride 32 tires (control tire for our nationals and ETS). My car was tail happy in the morning but after a few changes I had a very good car. My friends that were comming from the T3 2012 copied their setup on the T4, but that wasn't perfect. After they had driven my car, they started to copy my setup And they are better drives than me (top 5 guys from Belgium), so they what a good car should drive like.
This was my setup: http://f.cl.ly/items/163b0Z3l002W3y2...2019:56:52.png
morgoth is offline
Old 10-21-2012, 12:36 PM
  #881
how did you find that diff weight? did you use any other or just went with that weight?
Old 10-21-2012, 12:44 PM
  #882
morgoth's Avatar
I build the car completely like the kit setup and went from there. With 700 the car was too nervous on turn in and less predictable. The 2000 oil calmed the rear down off-power and made it more predictable.
morgoth is offline
Old 10-21-2012, 01:53 PM
  #883
Skiddins's Avatar
What did they have different on their setups that did not work?
Skiddins is offline
Old 10-21-2012, 01:57 PM
  #884
morgoth's Avatar
Short, low front link and a long rear link. I tried the short front link and my car had too much roll in the front. The rearend was less predictable and my overal steering increased a little imo. The car was more stable with the medium front link. And after adding a 0.5mm link, the frontend was a bit calmer. I could push the car pretty hard and it was fast in the chicanes.
I should have tried a 2mm shim on the rearbulkhead, but 1mm was also great
morgoth is offline
Old 10-21-2012, 04:56 PM
  #885
Meradin's Avatar
Trader Rating: 19 (100%+)
Not to distract you from those and I am not sure where you are located. i f you are in the states I have found these to work great for storing my tires. They can be found in most local hardware stores like home depot, menards, and lowes. They hold a complete set of tires. There is a seam on the top which I seal with shoe goo and vinyl tape.
Meradin is offline
