Xray T4 '13
Old 07-17-2014, 01:27 AM
  #5581
+1 for RCMart, prices are reasonable and delivery is more reliable and faster then their competitors, the only better option is to buy a used t4 13 roller and strip it, this is the cheapest way in the long run.
cheers
oldenuff
oldenuff is offline
Old 07-17-2014, 02:09 AM
  #5582
tc3team's Avatar
thanks guys, good suggestions
I were wondering if something else would fit. It doesn't bother me if the pin does not have a flat on it, minor issue (imo).
tc3team is offline
Old 08-10-2014, 03:39 PM
  #5583
M3Roc's Avatar
Trader Rating: 108 (100%+)
Can anyone please tell me if the '14 chassis is backwards compatible with the '13 model? I'm looking for a new chassis and found a '14 for a good price but I don't want to buy it and then find out it wont work.
Thanks!
M3Roc is offline
Old 08-10-2014, 04:16 PM
  #5584
chasingthepack's Avatar
Thanks!
no it wont work, ,you will need the 13 chassis
chasingthepack is offline
Old 08-10-2014, 04:37 PM
  #5585
Bigz84's Avatar
Trader Rating: 23 (100%+)
Thanks!
Not sure what your trying to do, but I can sell you a RX4 V1 chassis. this chassis has the original suspension mounting plus the newer 14 version. mounting.
Bigz84 is offline
Old 08-10-2014, 04:51 PM
  #5586
M3Roc's Avatar
I just need a new chassis for my T4'13.. I found one online that's for a T4'14 and I was wondering if the two were backwards compatible.
M3Roc is offline
Old 08-10-2014, 06:34 PM
  #5587
Regional Moderator
CarbonJoe's Avatar
Go to Xray's web site and download the parts cross reference list. Then you can see for yourself what parts work on which cars.
CarbonJoe is offline
Old 08-10-2014, 09:48 PM
  #5588
Trader Rating: 22 (100%+)
The RX4 chassis uses Spec-R R1 toe blocks. I've never tried to mount the T4 2014 toe blocks to that chassis and am not sure they will be a direct fit (with correct geometry). However it will work perfectly with with the standard T4 2013 mounting blocks.
Troy Carter is offline
Old 08-10-2014, 10:01 PM
  #5589
erchn's Avatar
The r1 blocks do not fit the '14 chassis. Very very close, but no.
erchn is offline
Old 08-28-2014, 05:25 PM
  #5590
anythinggas's Avatar
Trader Rating: 18 (100%+)
I know that somebody has asked this question, but i can't seem to find a answer. I run the xray T4 on a prepped asphalt track and it just don't handle as good as my T3 most tell me that the shocks are the issue. they say short shocks only work on carpet. is there a way to install the shocks from a T3.
anythinggas is online now
Old 08-28-2014, 05:56 PM
  #5591
erchn's Avatar
http://www.rctech.net/forum/electric...415-9.html#134
erchn is offline
Old 09-06-2014, 07:10 AM
  #5592
hi guys, short shocks long shocks is a preference thing and should not hinder you on asphalt, i run my t4 13 on asphalt on a large track and trust me it works, your t4 is just missing something in the setup, whats the problem with it ? does it not turn as well or does it spin out to easily?, or does it not rotate mid corner as well?, there are solutions to all these problems the trick is just finding them, i went through this for months when i first got my t4 13, i could not get it to turn but eventually i found a way. and now i couldn't be happier
cheers
oldenuff
oldenuff is offline
Old 09-06-2014, 11:01 PM
  #5593
metalnut's Avatar
Trader Rating: 36 (100%+)
My T4'13 took a pretty good beating this summer on asphalt. I'm considering replacing the chassis, but I'm wondering what my options are. I know CSO has a few options, RSD has a conversion (out of stock), and I think Arrowmax has something too. Finding things in stock is proving challenging. Any thoughts on which way I should go? I don't think I want aluminum.
metalnut is offline
Old 09-07-2014, 12:33 AM
  #5594
hi guys, i tried the arrowmax chassis and it was great until it was involved in a nasty prang, not sure if the genuine would have been better off, maybe but not sure, have not tried the cso but judging by some of their other stuff i would not trust it, best bet is to trowel through the for sale sections and try find a good used chassis or roller, but one like that may take time.
cheers
oldenuff
oldenuff is offline
Old 09-07-2014, 11:14 AM
  #5595
Email Reflex about an RX4 chassis. They just got their own router so they can make one on demand nkw and it is a good chassis with or without their tow block conversion.
