Xray T4 '13
Old 08-18-2013, 07:44 PM
  #4741
cwoods34's Avatar
Originally Posted by Adam B View Post
Has anybody ever ran ECS shafts in the rear? If so, what did you notice, if anything?
I noticed a slight increase in rear side-bite and stability. I moved them to the back a couple of months ago when I started running a front gear diff and I've left them back there ever since!
cwoods34 is offline
Old 08-18-2013, 07:55 PM
  #4742
Adam B's Avatar
Did you replace the rear 50mm axles with the 50mm ECS or 52?
Adam B is offline
Old 08-18-2013, 08:00 PM
  #4743
RobS's Avatar
Exact same thing I found. It's not a necessary upgrade but I did like the feel of having them in. I use 50mm in the rear.
RobS is offline
Old 08-18-2013, 08:23 PM
  #4744
Are people using the genuine ecs shafts or one of the many aftermarket brands? I'm looking to get some and what to know what's best
d.k.vmatt is offline
Old 08-18-2013, 09:33 PM
  #4745
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I use and prefer the narrow axle RSD ecs axles.
andrewdoherty is offline
Old 08-19-2013, 04:46 AM
  #4746
jlfx car audio's Avatar
Trader Rating: 37 (100%+)
Me 2
jlfx car audio is offline
Old 08-19-2013, 06:15 AM
  #4747
domekat's Avatar
Anyone know if these will fit the front of a T4, a full set for not much more than a pair from xray
http://www.amainhobbies.com/product_...er-Set-10-16mm
and the rear
http://www.amainhobbies.com/product_...Stabilizer-Set
domekat is offline
Old 08-19-2013, 08:27 AM
  #4748
RC MARKET's Avatar
Arrowmax New Option Parts
RIDE New Short Shock Spring 8 types
Attached Thumbnails Xray T4 '13-am-t4-308037.jpg   Xray T4 '13-am-t4-308037a2.jpg   Xray T4 '13-am-t4-308037b1.jpg   Xray T4 '13-ri-28040.jpg   Xray T4 '13-ri-28047.jpg
RC MARKET is offline
Old 08-19-2013, 03:06 PM
  #4749
cwoods34's Avatar
50mm....... 52mm in the back can feel unstable depending on diff and arm angles.
cwoods34 is offline
Old 08-19-2013, 03:15 PM
  #4750
reg
What's the wear like for those that have ran week in week out since the car came out,
More the high cost things like diff out drives and drive shafts,
reg is offline
Old 08-19-2013, 03:17 PM
  #4751
Bigz84's Avatar
Trader Rating: 23 (100%+)
good info Cody, thanks
I will be putting 50mm ecs in the rear of my car tonight.
Bigz84 is offline
Old 08-19-2013, 03:32 PM
  #4752
erchn's Avatar
The only thing I've replaced out of regular wear is bearings...and I've probably put 2.5-3k laps on the car. A couple parts have broken, but that was due to electronic or driver failure.
erchn is offline
Old 08-19-2013, 03:35 PM
  #4753
reg
Awesome,
That's what I was hoping to hear from Xray,
The quality of some kits has gone down lately but glad Xray arnt one of them
reg is offline
Old 08-19-2013, 03:51 PM
  #4754
cwoods34's Avatar
To add, make sure to use quality bearings at the hubs and maintain them regularly, especially with ECS shafts. Cheap or worn bearings cause more axle wobble.... The excessive vibration seems to affect ECS shafts more than regular ones, especially if they aren't built properly
cwoods34 is offline
Old 08-19-2013, 05:04 PM
  #4755
Adam B's Avatar
Really? How about run it before doing so, see what times you get. Then put them in to see if you really feel a difference.
Adam B is offline
