Xray T4 '13
Old 06-16-2013, 11:16 AM
  #4156
Jerz616's Avatar
Trader Rating: 49 (100%+)
Originally Posted by Chaz955i View Post
FYI.. Purchased a Trinity Killshot and the motor fit fine. Looks like any fit issues have been addressed. I did rotate the end plate to index the solder tabs where i like them but that was a 30 second process.
Mine fit fine as well until I looked at the underside of the chassis. You could see where the motor was pressing into it and making an indention. Jim sent me two new end plates and all is fine now.
Jerz616 is offline
Old 06-16-2013, 12:44 PM
  #4157
Chaz955i's Avatar
So in other words it didn't fit.
Glad they got you taken care of.
Chaz955i is offline
Old 06-16-2013, 01:54 PM
  #4158
Jerz616's Avatar
I guess you could say that. Most people were saying it wouldn't even screw onto the motor mount. Mine screwed on fine. It wasn't until I was changing the battery tape that I noticed it. I guess I was just trying to say check the underside. It's very inconspicuous if your not looking for it.
Jerz616 is offline
Old 06-16-2013, 08:46 PM
  #4159
Chaz955i's Avatar
Good tip. Hopefully the latest run has none of the issues you and others have experienced.
Chaz955i is offline
Old 06-17-2013, 12:40 AM
  #4160
B00t13g's Avatar
The third run should be fine. The motor I got from ea mounts up perfect. The one I bought locally does not.
B00t13g is offline
Old 06-17-2013, 07:01 AM
  #4161
chasingthepack's Avatar
ok ,a bit more help is needed,im almost there with how i want the car to feel ,however im still having to wait in the turns for the car to grip so i can get back on the power,this is on asphalt and only really occurs in the slow corners ,everywhere else on the track the car is perfect,it just pushes on entry to these slower corners,i didnt get much chance for changes as it rained,i was 1 sec off my pb in round 1 matching my fastest lap time 14.69,in round 2 i put in the wrong battery and dumped after 12 laps,but the time sheets had me on a new pb and i managed a new fastest lap of 14,51 all i changed was the front inner links i took out the 1mm shims,# 1 hole no shims, the outer has 2mm
2deg camber 350 cst 4 hole 1.1 2.7 shock shimmed 3mm and using the third hole out 1.4 roll bar and no ackerman shims rh 6mm,1.7 top deck no screws removed
rear: inner link 0 shims 4mm outer #1 hole 1.5 camber 3.5 toe in 2.7 350cst 4 hole 1.1bottom of shock shimmed out 2mm 3rd hole out from center rh 6.4 and specr r rear 1 hole uprights 1.2 roll bar
any ideas,what to try next,it was around 10 deg c not sure of track temp i was using muchmore acute additive, on 32ry's i would put up a set up sheet but its alot of hassle due to size,(if someone can let me know how to reduce its size id be greatfull)well what to try next any advice appreciated
i have made 2 changes already to see how it will work next week and those are ive gone from 2mm outer front link to 1mm and shock mount has gone back to hole 2 from center,whats your thoughts?
chasingthepack is offline
Old 06-17-2013, 09:41 AM
  #4162
Skiddins's Avatar
Best thing for setup sheets is to fill out one on the Xray website, then post a link to it here.
Skiddins is offline
Old 06-17-2013, 10:13 AM
  #4163
here it is,let me know what you think
http://forum.teamxray.com/xform/inde...D=430&setup=t4
Old 06-17-2013, 10:33 AM
  #4164
erchn's Avatar
I'd probably try less rear toe, or maybe removing the front arm sweep.
erchn is offline
Old 06-17-2013, 10:56 AM
  #4165
thanks ethan,the 3.5 toe is needed to get around the banked sweeper,i have tried less but then i lose the rear,what will removing the arm sweep do?
Old 06-17-2013, 10:58 AM
  #4166
erchn's Avatar
I think it tends to numb the front-end a bit, it'll also be slightly narrower which should help it be more aggressive going into the corner.
erchn is offline
Old 06-17-2013, 11:02 AM
  #4167
TXBandit's Avatar
maybe soften the front springs.. helps steering at turn in under deceleration negotiating slow corners and roll through center and transfer weight back to rear when accelerating...... rear toe IS a bit much too...
TXBandit is offline
Old 06-17-2013, 12:00 PM
  #4168
Try 450 front and 400 aft in your damper and give front anti dive.
With springs all around of 2.7 you need ticker damper oil.
I talk about Xray oil.
Thanks Ed
eded1 is offline
Old 06-17-2013, 12:29 PM
  #4169
it seems strange (to me anyway) that its fine into faster turns but as soon as i get to the slower infield it loses bite
Old 06-17-2013, 12:36 PM
  #4170
the fast guys are running the same toe and there just squeezing in 22 laps im 3 sec off a 21 over half a sec a lap slower,hence why i think its all to be found in the front settings
