Xray T4 '13
Old 06-15-2013, 02:47 AM
  #4141
chasingthepack's Avatar
Originally Posted by JOE SI View Post
Yea same thing, straightening the shock.
Don't know what it actually does, but I'm going to say it makes the suspension more efficient
i tried to work out why it works,and all i could come up with is it stops the shock from binding,i took the shock off the car and put sideways pressure to the shaft and the shock felt as though it was binding,so with the shock more vertical there is less binding ,so a smoother shock action is the result
chasingthepack is offline
Old 06-15-2013, 06:12 AM
  #4142
TT_Vert's Avatar
Trader Rating: 72 (100%+)
Does it give more rear traction? I'd guess it's all about arm leverage vs. The shaft similar to angling the shock on the tower.
TT_Vert is offline
Old 06-15-2013, 12:12 PM
  #4143
ali_g's Avatar
anyone know what brushless motor (gold in color) Martin Hudy is using at ETS?
ali_g is offline
Old 06-15-2013, 12:27 PM
  #4144
Craig W's Avatar
lipotech
Craig W is offline
Old 06-15-2013, 12:31 PM
  #4145
ali_g's Avatar
Originally Posted by Craig W View Post
lipotech
anyone got experience with it?
ali_g is offline
Old 06-15-2013, 01:12 PM
  #4146
i dont believe it does,just smoothes out the transition
Old 06-15-2013, 01:13 PM
  #4147
TT_Vert's Avatar
How would you say it smooths it out? And what transition are you referring to? Side to side or front to back?
Dave
TT_Vert is offline
Old 06-15-2013, 01:15 PM
  #4148
Dave
i would say all as it just makes the shock action smoother with out any binding,thats imho though
Old 06-15-2013, 01:22 PM
  #4149
TT_Vert's Avatar
Xray states it as a tuning option so I'm trying to figure out the details. I don't think they'd angle the shocks the way they do if the shocks aren't smooth at that angle. They are a bit ambiguous when they state "move the front shock forward and rear rearward". They state what the effect is (Oddly it states the exact same thing for front/rear that you loose corner entry steering and it's more stable doing either) but I just don't know If you are supposed to equally space the top/bottom or offset more on top or bottom.
Dave
TT_Vert is offline
Old 06-15-2013, 01:50 PM
  #4150
Dave
i have a 3mm shim front top and a 2mm shim rear bottom no others,it also depends on your wheel base and where you place the shims
Old 06-15-2013, 02:06 PM
  #4151
TT_Vert's Avatar
Right, so a definitive Washer here, this result, washer there, that result would benefit us all. I'm not good enough to discern such a small change to distinguish if it has helped but my curiosity has gotten the best of me here.
Something like
washer top front: result
Washer bottom front : result
Washer top rear : result
Washer bottom rear: result
Dave
TT_Vert is offline
Old 06-15-2013, 03:13 PM
  #4152
This was posted a while ago by Alex Hagberg on the Xray Forum:
"When you space the shocks out equally both on the top and bottom, this somehow makes more cornerspeed, which ist noticeable especially in highspeed corners. The car will stop less. Actually I think the shimming will take away a bit of traction from that end of the car. In the front I use 4mm shims from the top mounting and 2 at the bottom to have the shock mounted in a vertical line. In the rear I use 2mm at the top and bottom."
I recall he stated in another tread that with 3mm on top he will use 1 mm on the bottom and with 2 mm on the top he uses non on the bottom (Thats all in the front).
nevergiveup is offline
Old 06-15-2013, 03:55 PM
  #4153
TT_Vert's Avatar
That's much more informative thank you. I know I read it somewhere I just couldn't find it. I'll have to look through the xray forum a bit, maybe that's where I ended up one day when I googled something about the t4. What it appears is he likes to keep the shock vertical from a cross sectional view. And it appears it takes 2 top washers up front to do that w/ 0 at the bottom and in back it is vertical w/ no shims.
Dave
TT_Vert is offline
Old 06-16-2013, 09:10 AM
  #4154
well at the end of the day i was quite gutted,first run this morning and im 1 second off my pb,second run i im on for beating my pb and i put the wrong battery in and dumped at 12 laps,then the heavens opened and ruined any chance of going faster,the car itself has come along way and the handling was the best yet,even in the wet without any adjusment it felt good
now ill have to wait another week to try and get on pace with the leaders
but even with my 1st round time i managed 6th in the A
Old 06-16-2013, 11:53 AM
  #4155
Chaz955i's Avatar
FYI.. Purchased a Trinity Killshot and the motor fit fine. Looks like any fit issues have been addressed. I did rotate the end plate to index the solder tabs where i like them but that was a 30 second process.
Chaz955i is offline
