Xray T4 '13
Old 05-08-2013, 07:30 PM
  #3481
Dan
Dan's Avatar
Trader Rating: 52 (100%+)
I knew it! LOL
Dan is offline
Old 05-08-2013, 10:37 PM
  #3482
syndr0me's Avatar
Trader Rating: 32 (100%+)
Any idea what might cause the right front of the car to be tweaked? I've tried loosening everything on the chassis, rebuilding shocks, etc. It's off by a good bit, yet the rear tweaks out fine.
syndr0me is offline
Old 05-09-2013, 12:13 AM
  #3483
defcone's Avatar
Trader Rating: 15 (100%+)
Cracked bottom/top deck, bent bulkheads
defcone is offline
Old 05-09-2013, 01:07 AM
  #3484
scoyle's Avatar
If loosening off all screws including the shock tower screws, top deck and bulkhead screws does not sort it then I would agree with defcone and check the bulkheads to see if they are bent. The only way I have been able to do this in the past was to strip the car down and put each piece of alloy on a flat glass surface and see if it's bent. I have not had this happen with the Xray but did have it happen once with a TC6.
As a side note, when you are tightening up the screws I have found it useful to have a long iron bar that I put across the two shock towers and push down while I tighten each of the top deck screws.
scoyle is offline
Old 05-09-2013, 02:53 AM
  #3485
G-kenny's Avatar
That's because you have yet to actually run the Xray
G-kenny is offline
Old 05-09-2013, 03:21 AM
  #3486
Trader Rating: 17 (100%+)
Maybe a bent hinge pin?
lethallee69 is offline
Old 05-09-2013, 05:38 AM
  #3487
Default tweak
I have found that sometime you can tweak the chassis between the front rear arm holder and the front of the chassis, usually the right hand side from clipping track markings. undo the hangers from the arms then check to make sure the chassis is flat, then re-tighten.
also when the you have the chassis sitting flat press your thumb down in the centre of the shock tower and undo the four screws then re-tighten.
make sure that screws on the chassis are sitting flush.
matt prigmore is offline
Old 05-09-2013, 08:47 AM
  #3488
syndr0me's Avatar
Thanks for the input guys, I'll tear down the front and make sure everything is perfectly flat. This particular car had a few spectacular crashes at carpet nats clipping sweeper on with the right front, so it's possible something isn't straight.
syndr0me is offline
Old 05-09-2013, 10:23 AM
  #3489
clparsons123's Avatar
hello everyone! well finally since nationals i have had time to look at my car and write the setup down that i won with in 13.5 touring . i ran the same car in 17.5 so it will work good with class also . i wound up finishing 5th overall in 17.5 because of bad luck in the mains . anyway here is the link to the setup (http://forum.teamxray.com/xform/inde...D=365&setup=t4)
if you have any questions just ask
thanks
Cory Parsons
clparsons123 is offline
Old 05-09-2013, 11:05 AM
  #3490
TT_Vert's Avatar
Trader Rating: 70 (100%+)
I'm sure this has been answered but I'm not finding it. I want to purchase spare rear arms but the kit part # shows 303163 yet it shows 3 sway bar mounts. However it only has a 2 sway bar mounts according to my part # lookup. The arms I have are the Hard arm and I "think" the P/N is 303167. My question is, is 303167 in fact the Hard arm or is this a different material and is this in fact the kit rear arm?
TT_Vert is offline
Old 05-09-2013, 02:11 PM
  #3491
Skiddins's Avatar
I think the pictures are just for reference. Just order the right part number.
Skiddins
Skiddins is offline
Old 05-09-2013, 03:22 PM
  #3492
rcguyfpr's Avatar
Trader Rating: 36 (100%+)
Question about the anti-roll bar. No matter what I do to the mounting set screws or adjusting the set screws by the end of the bar, left and right just have uneven reaction. All arms go up&down freely. However, when lift up left, right will come up; but life up right, left only moves a little (shocks off).
Front 1.4 and rear 1.2 bar, similar case. How do I fix it? thanks!
rcguyfpr is offline
Old 05-09-2013, 03:25 PM
  #3493
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
Raise or lower the ball cups that support the anti roll bar.
Raise or lower one side by turning the ball cups until both sides react simultaneously.
IIGQ4U is offline
Old 05-09-2013, 04:57 PM
  #3494
Skiddins's Avatar
Also, put the roll bars on a flat surface like a piece of glass and check that they are flat and not twisted.
Skiddins is offline
Old 05-09-2013, 05:15 PM
  #3495
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
The tiniest tweak in the bar can throw it out alot on the car.
dontfeelcold is offline
