Xray T4 '13
#3241
I noticed today that the metal ball that the lower shock mounts to is very tight and doesn't pivot properly. I checked the T4 build manual and it says to have the shiney side away from the metal ball ??? is this right ? TBH I tried it both ways round and its still tight. Ive never had this problem with any xray before. Any ideas
Or change out the plastic end...
#3242
-The shiny end goes against the arms.
#3243
On the bottom, the shiny side faces away from the car.
On the top, the shiny side faces the car.
Make sure the shaft is not threaded too far into the eyelet.
Try unthreading the shaft and see if the joint loosens.
There should be no need to polish or reshape/crush anything.
#3244
With the T4, unlike with other brands of cars, you should have the ridge on the shock shafts that come before the threads showing. In other words, just loosen up your rod ends and it should be great.
#3247
Do nitro cars also run on the same track?
#3248
So perhaps CS Max Grip, Rheinard MR33 or any of the other thicker oil based additives.
I always use warmers with the additive, both for around 20 mins.
#3252
can anyone tell me what the is size in millimeters of the rear suspension arm
where the upright between
#3253
I have built my gear diff with just the paper gasket, and filled it as per instructions to 9.2 grams in weight. Im wondering is this to much oil ?? mine leaks between the two diff halves.
#3255
Definitely check if the 2 halves are lined up right since I've never heard of an xray diff leaking and not even a drop out of mine so far, I didn't line the halves up on my old spec r diff in my photon one time in a rush and the oil was gone in the first few hrs probably sooner but checked after a few hrs
