Xray T4 '13
#3106
When you are that late in the corner, just getting on throttle, your car is probably dumping too hard to the outside tire and loosing traction. A stiffer rear bar will help, raising your rear arm mounts .5mm or the full .75mm would also help. Other less dramatic options, depending on setup, would be equal oil in all 4 shocks, if you are running a lighter oil in the rear, or standing your shocks up one on the rear tower.
#3108
When you are that late in the corner, just getting on throttle, your car is probably dumping to hard too the outside tire and loosing traction. A stiffer rear bar will help, raising your rear arm mounts .5mm or the full .75mm would also help. Other less dramatic options, depending on setup, would be equal oil in all 4 shocks, if you are running a lighter oil in the rear, or standing your shocks up one on the rear tower.
#3109
Location: El Pueblo de Nuestra Señora La Reina de Los Ángeles del Río de Porciúncula, California, Unites States of America
Trader Rating: 40 (100%+)
Thinking of buying a T4 today, what spare parts or hop-ups are good to have in-hand? what breaks often?
#3112
http://www.rc-mushroom.com/product_i...mm-pin-p-26402
Not exactly close to Texas, but it is in stock.
#3114
#3115
+1 to EA's Snowbirds setup! We also tested it with 2.7 springs front and rear and tried a spool out... It worked good on our tighter layouts.
#3116
#3118
Do you have any links to photos of the track at all?
That might help others give advice on handling.
I run 450 oil in my car and found it to be a bit more predictable when being thrown around on carpet, this was with 10degC track temps etc in a cold hall.
Quite a few other drivers have been using 400cSt front and rear here (this was using Sorex 28JB's)
#3119
Hey guys where can I find a set of t4 shocks at a good price?
