Xray T4 '13
Old 02-13-2013, 03:42 AM
  #2746
StevenOlsen's Avatar
Originally Posted by Nathan Wilson View Post
so your just moving where it is mounted? on the right hand link instead of in the middle? does this not cause the steering block to hit the hubs? as i am close as it is with the standard set up, i never ran a T3
yes i just moved the point where it is mounted :-)
yes the block hits the hub but this i normal on most touring cars :-)
StevenOlsen is offline
Old 02-13-2013, 05:12 AM
  #2747
i hit the hubs as it is with standard set up and reduce my epa to stop it. so how would moving the link give me more steering throw if it physically cannot move anymore?
Nathan Wilson is offline
Old 02-13-2013, 05:21 AM
  #2748
defcone's Avatar
Trader Rating: 15 (100%+)
If you're using the standard setup, it shouldn't hit the hubs.
defcone is offline
Old 02-13-2013, 05:46 AM
  #2749
well maybe not hitting it but its damn near close, and i have had to reduce my epa. anything to do with the servo im using? its a savox 1251mg? i can remember when setting it up i had to reduce my epa as it was hitting something and causing the chassis to tweak
Old 02-13-2013, 06:17 AM
  #2750
defcone's Avatar
That's just the servo moving instead of the steering rack moving because of too much EPA, it was designed not to hit as it was said to increase corner speed.
defcone is offline
Old 02-13-2013, 06:40 AM
  #2751
Skiddins's Avatar
The shims on the ball joint in the middle of the steering rack (that link to the servo) should hit the steerings arms, before anything comes into contact with the steering knuckles/C hubs etc.
Skiddins is offline
Old 02-13-2013, 10:05 AM
  #2752
So if its hitting surely you wouldnt gain anything with the mod as its at its limit?
Old 02-13-2013, 10:11 AM
  #2753
Xpress's Avatar
No....the spacers where the link mounts to the bellcrank bridge limit the throw because the arms hit the spacers. When you move the link to the bellcrank arm you eliminate the spacers that also act a steering limiter. You'll be able to get another 4 or 5 degrees of steering throw...
Xpress is offline
Old 02-13-2013, 11:31 AM
  #2754
danny250r's Avatar
Trader Rating: 57 (100%+)
anyone try the reflex soft bladders in shocks whats your thoughts on them if so
danny250r is offline
Old 02-13-2013, 12:31 PM
  #2755
B00t13g's Avatar
I don't believe they have bladders for the t4 yet? They worked just fine on the t3.
B00t13g is offline
Old 02-13-2013, 03:00 PM
  #2756
danny250r's Avatar
the 10mm dont fit?
Old 02-13-2013, 04:51 PM
  #2757
cwoods34's Avatar
They do not fit T4 shocks. You can "fit" them on but as soon as the suspension gets worked it will suck the bladder down in. I would LOVE some properly sized ones from Reflex, along with the 6-hole pistons that were discussed recently
cwoods34 is offline
Old 02-13-2013, 10:05 PM
  #2758
The RSD's work really well for me.
But you have to remove part of the top collar so it screws down further and clamps enough. (make collar about 5.8mm on linisher or similar)
davo705 is offline
Old 02-15-2013, 09:54 AM
  #2759
Slapstick10's Avatar
Trader Rating: 29 (100%+)
Default A fifth body post?????
I was interested in adding a fifth body post to my t4. I am planning on using the hole that was pre drilled in the front of the top deck. My question would be will adding the post stiffen the chassis or effect the cars rotation. I can reem the hole in the body a little larger to allow a bit of flex but is it needed?
Slapstick10 is offline
Old 02-15-2013, 10:13 AM
  #2760
jlfx car audio's Avatar
Trader Rating: 37 (100%+)
I put mine on top of the steering post (the side is outside of sweeper just in case I want to run a crap body ) works great and don't seam to tweak chassis like the top deck would (possibly cracking top deck also)
jlfx car audio is offline
