Xray T4 '13
Old 11-21-2012, 10:04 AM
  #1621
Originally Posted by Mera'din View Post
So, they no longer include a setup book with the cars. The website claims this is so you can get the latest most up to date version...whatever, I have one that came with my t3'11.
My question is, the 4 is so much more optimized, what changes are made in the setup book to accommodate the new design? Has anyone compared them?
Everything covered in the previous book applies to the new car. Having said that, the only topic I feel they could have covered in an updated version of the book is their new shock design. It is my understanding that because the the overall damper movement is quite small(much shorter than previous designs), to have any real affect they needed to flow more volume than the std dia dampers. Hence the reason for the increase in bore size. Furthermore, we now must use lighter oil to compensate for this and some may not understand why.
CoreyW. is offline
Old 11-21-2012, 11:10 AM
  #1622
C@T's Avatar
As the mounting point for the shocks did not move to much they do see the same change in length at a given rate of compression.
Reason to make them bigger bore might be having same volume of oil working,
and (guessing) make the more effective and smother.
C@T is offline
Old 11-21-2012, 01:12 PM
  #1623
ByteStream's Avatar
Originally Posted by Dan View Post
Got a question, so I have some backup 50mm ECS driveshafts. Will they work with the stock plastic spool cups? Or do I have to upgrade to the aluminum diff outdrives and run blades as well?
I would not run the 50mm shafts in the plastic spool cups without a slight modification. Stick a 1mm shim between the spool and each outdrive. You'll have to shave the shim a little, to make it a little more 'sqaure' to fit in there. Otherwise, you will most likely break the outdrives even without hitting anything. The shaft does not sit far enough into the outdrive unless you do this. Of course you can get aluminum outdrives that help the situation.
ByteStream is offline
Old 11-21-2012, 08:54 PM
  #1624
waOscar's Avatar
Technically you are correct, however the ackerman is pictured totally wrong and the book still refer to "quick roll centre changes". I love the xray product, but for Luxury, Prememium, Optimised, product etc etc, I think not updating the Set Up book is a bit slack.
waOscar is offline
Old 11-21-2012, 09:53 PM
  #1625
What really matters is that the car is better.
Have you contacted Xray with your concerns? They might update the setup guide if there is enough demand.
CoreyW. is offline
Old 11-21-2012, 11:54 PM
  #1626
Meradin's Avatar
Trader Rating: 19 (100%+)
x3
The car has seen considerable changes...the setup book has not and it references old parts and incorrect parts. I'd like to see an up to date version myself. The book was written for the t2!
Meradin is offline
Old 11-22-2012, 01:24 AM
  #1627
RCknight's Avatar
Nice mod Sean. I would really like to use it, and would prefer the thinner lighter hard bumper. Now can you CNC a few and sell them. lol
Originally Posted by Sean B. View Post
T3 hard bumper shaved down to T4 height, with small carbon brace. After having not run TC in 5 years, I can say I tested it thoroughly and it works great. Couldn't bring myself to even try the stock bumper.
RCknight is offline
Old 11-22-2012, 06:03 AM
  #1628
Thanks Mr. Knight
For the bumper, We just marked a line around the whole thing with a silver sharpie, then took it to a belt sander. Cleaned it up with a dremel. You just want to make sure to shave the top part of the bumper down.
For the little brace, if you want one just message Damon at diggitydesigns.com and he will ship you one for pretty cheap i would think
All credit for this mod goes to Damon Converse
Sean B. is offline
Old 11-22-2012, 06:25 AM
  #1629
MikeCruz's Avatar
Default Binding rear Diff
Happy RC Thanks Giving Fellas!!
Question: I'm just going over while building my car and I just noticed that the rear gear diff that every 3/4 of a Turn while holding belt to get the diff action there's, which feels like would be a little pebble caught in 1 of the gears
I cut away any excess plastic from when I cut gears off from the tree and made sure where smooth
Is that or can that be something that wears in as its new, or should i reopen it and c where it's coming from?
Thanks guys!! Mike...
MikeCruz is offline
Old 11-22-2012, 07:58 AM
  #1630
locked's Avatar
Mike, I've built 4 xray gear diffs and all have been buttery smooth. It shouldn't be notchy.
To all you guys complaining about the setup book not being updated. Really??? How many other manufacturers give you any form of setup book with their cars or on their site? The car might be a little different now, but the physics and concepts haven't changed. Maybe they never should have included a setup book to begin with. It's a lot of work to keep you guys satisfied. An outstanding product apparently isn't good enough.
locked is offline
Old 11-22-2012, 09:30 AM
  #1631
MikeCruz's Avatar
[QUOTE=locked;11469607]Mike, I've built 4 xray gear diffs and all have been buttery smooth. It shouldn't be notchy.
Notching is the word I was looking for that it is doing every 3/4 rotation. Thanks
I will rebuild the Diff and c where is coming from.
Greatly aprieciated!! Happy Holidays!! Mike...
MikeCruz is offline
Old 11-24-2012, 06:40 AM
  #1632
Skiddins's Avatar
Another Friday, another testing session.
Again, kit carpet setup except 3mm bump steer, 2000 in diff and 2.7 rear springs in hole 3.
Having the rear shocks in hole 2 made the car feel slightly safer, putting them in hole 3 did absolutely nothing for the fastest laptimes (down to the nearest 100th of a second!)
No Grainger last night.
Cars 2 and 3 are also T4's, the bright red car had 2.5/2.3 springs, the orange car had 2.7/2.7, but i believe his links are middle hole.
Will get to run exactly the same track tomorrow so will try a couple of things to see how laptimes vary.
I got ftd, but car 7 also borrowed one of my bodyshells (blue with yellow and orange stripes, but his blue is darker), the front 3 of us are fairly close the entire way through.
+ YouTube Video
P.S. after checking my car mid week, I noticed I had different wheelbase settings at the back on each side (yes, I know, 'What a Knob' ), it's been like that since I first built it so tonight was the first time both sides were 'kit'
Skiddins is offline
Old 11-24-2012, 02:46 PM
  #1633
haywood's Avatar
Trader Rating: 49 (100%+)
Default Rear body post
Can I turn them around so my 2012 body holes match up? Thanks
haywood is offline
Old 11-24-2012, 03:38 PM
  #1634
Skiddins's Avatar
No, the T4 rear posts are 10mm closer together so it's best to put them on the back;
Skiddins is offline
Old 11-24-2012, 03:40 PM
  #1635
defcone's Avatar
Trader Rating: 15 (100%+)
To be fair, that setup book is like a manual to some. They tell you to refer to it but when you go and look at it, some parts don't apply to this car.
defcone is offline
