Old 09-17-2012, 06:54 PM   #1
Default Help me build a TC4 Club Racer for speed!
I want to buy a club racer for top speed runs.
I want to stay on a low budget.
I want the car to do at least 60mph.
Can you recommend a motor/ESC combo and the correct gearing to go along with it?
Thanks!
2010GTR is offline   Reply With Quote
Old 09-18-2012, 07:56 AM   #2
Speed costs money. How fast do you want to go?
The TC4 club racer is a bad start if you want to build a car for all out speed. A modern belt drive car would be better because the belt drive is more efficent.
Speed and Budget are 2 words that just don't go together. You will need a high end speed control, something that will handle a 3.5 turn motor. Also you will need the smallest spur/biggest pinion that will fit in the car, and that means modifying the TC4 chassis.
jiml is offline   Reply With Quote
Old 09-18-2012, 08:19 AM   #3
MikeXray's Avatar
Trader Rating: 73 (100%+)
60mph really isn't that hard to get too, especially since you are not building it to a spec class, you can use a speedo that supports 3s lipos and a 4.5 mod motor will get you there as long as it stays together. You can get over 60mph with 2s, but it takes some tuning, the 3s would make it easier. I imagine that keeping the gears from stripping might be an issue though
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 09-18-2012, 10:00 AM   #4
Suspended
Smile
The aluminum shaft will wobble alot at 50+mph, but it can be done with steel outdrives only in the rear, foam Tires(preferrably nitro), and shim your diffs tight.... I think 80mph is the real challenge instead of 60mph... I say get a tekin RX8 esc, and run as many as 6S in your Car...lol.. Good luck.....
bertrandsv87 is offline   Reply With Quote
Old 09-18-2012, 10:04 AM   #5
Suspended
As far as motor, I think a 2.5t tekin will do just fine.... There is One guy that did run a 2.5t on 3S, and got 84.2mph on youtube...good luck....
Old 09-18-2012, 10:06 AM   #6
snoopyrc's Avatar
Modified touring cars hit 60 all the time with 2s.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 09-18-2012, 10:13 AM   #7
Suspended
Tekin Rx8 $200 , tekin 2.5t/3.5t motor $83 , thunderpower 3S 65c pack $135 , GQ foam Tires $22(35shore front/37shore rear).....
Old 09-18-2012, 10:26 AM   #8
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Modified touring cars were hitting 60 with 5 cell nimh batteries 5 years ago. And remember, the TC4 was NOT designed to run that much motor. My guess is it will come apart on you after a handful of passes.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 09-18-2012, 01:03 PM   #9
jayjay283's Avatar
I run a losi excelorin right out of the speed T (4800 kv) on 3s in my t4 (aluminum cvd's though) been going strong for a couple years now. Never stripped a diff or spur and I dont baby it
jayjay283 is offline   Reply With Quote
Old 02-27-2014, 01:20 PM   #10
Trader Rating: 22 (100%+)
guys have ran tc4's up to the 140's, shaft drive is more efficient then a belt... id stick with a mamba monster esc and a 4s setup, maybe start with the 3800kv 4 pole
google isc speed challenge you should be able to find plenty of info, if not sign up and ask.
i've got a 2wd drive dragster we're getting mid 80's out of on 1s, like anyone else i know that runs high speed cars expect to spend some money and be able to not accept defeat...
noproblems209 is offline   Reply With Quote
