Old 04-07-2005, 01:35 PM   #16
Qwiglee's Avatar
So where can I get those little fans that go on the shaft when breaking in? Is the point of those fans to provide some load to the motor?
Brian Aldridge
Qwiglee is offline   Reply With Quote
Old 04-07-2005, 01:47 PM   #17
Arcee Newbie's Avatar
Hi. Speedtech.com usually has them. Or, I have an extra one you can have when I see you at Camarillo.
Arcee Newbie is offline   Reply With Quote
Old 04-07-2005, 01:50 PM   #18
Trader Rating: 40 (100%+)
Send a message via AIM to brians11
I dont really like the idea of the fan, unless your motor is shimmed perfectly with no slop, it will pull the motor out of that magnetic center, breaking in the brush to the wrong part of the comm, so when you put it in the car, it has to re-break in... thats just my opinion...
amp draw is a way of comparing a motor, like its been mentioned, you have to get the brushes seated in, then make a comparison, it's always nice to compare rpms as well... just a reminder for the effeciency of the motor for converting electrical power to mechanical power, so if that is bad, you'll need more amps to get the job done... also to worry about is the HP out of the motor, which is defined by RPM and torque...
and if you really wanna know, a dyno will tell you everything you could want, but the problem with them is we tend to look at the peak HP and RPM, when its very likely, we don't reach those numbers on the track, so to use the dyno effectively, you must know what rpm range you race in... thats why everyone says the best dyno is the track, because you see what the motor does in the range you are using it in...
Team Tekin | Superiorhobbies.com
brians11 is offline   Reply With Quote
Old 04-07-2005, 07:18 PM   #19
You really gotta use a combination of track and dyno or motor checker to find out what is what,it's all about having and interepeting data,Ive seen really fast guys use motor checkers to give them the data they need to make motor choices which is what it's all about.Simpler is better for me,so I would prefer to use a motor checker to get my data,also saves a lot of pit space.
Hyper1 is offline   Reply With Quote
Old 04-07-2005, 10:12 PM   #20
axel's Avatar
what i sconsidered mod class? anything below 19T?
axel is offline   Reply With Quote
Old 04-07-2005, 10:18 PM   #21
YEP
Old 04-07-2005, 10:28 PM   #22
Default amp draw
bottom line amp draw is the entry level scope for weeding out moters, dyno death is the only way to fly. so keep on burning your brushes up fellas you'll buy more
lickrim is offline   Reply With Quote
Old 04-07-2005, 10:54 PM   #23
EddieO's Avatar
R/C Tech Charter Subscriber
No load amp draw means very little.....
I've had rocket motors pull 5 amps, and some pull 10 amps........
I can make any stock motor pull 10 amps if you want....its a poor poor indicator of how good a stock motor is....
Cause even if you went of the theory a fast motor pulled 10 amps......a crap motor can pull 10 amps too....
You can use fans during break in, I just don't recommend it during the first 30-60 seconds (depends on the brush and the spring tension)....
Later EddieO
www.teambrood.com
EddieO is offline   Reply With Quote
Old 04-07-2005, 11:03 PM   #24
Default yup
eddieo thanks homie all my stuff is great , full blown tamiya testing this weekend the 19's are giong to rip thanks
charlie a
FS/FT TEAM ORION MOTOR PERFORMANCE MONITOR Sigearhead R/C Items: For Sale/Trade 9 11-14-2007 12:33 AM
Team Orion Motor Performance Monitor V2 Chris Mac R/C Items: For Sale/Trade 2 03-08-2007 12:04 PM
Team Orion Motor Performance Monitor Ginsu R/C Items: For Sale/Trade 2 08-19-2005 09:03 AM
Team Orion Motor Performance Monitor 2 rc-car-net Electric On-Road 15 03-15-2005 10:20 AM
Team Orion Motor Performance Monitor jrighter R/C Items: For Sale/Trade 6 03-11-2005 11:31 AM
