Old 03-14-2005, 10:34 PM   #1
heyman's Avatar
Send a message via Yahoo to heyman
Ni-mh Battery Charging Question
Hello , i have a battery charging question ! my charger is a tekin bc 112 with h28 software , the batterys are fecel 1.2 volt
1000 mah ni-mh batterys, useing 6 batterys total , which comes to 7.2 volts. these are a small purple battery used in an hpi micro . thanks for any help..Charles
heyman is offline   Reply With Quote
Old 03-15-2005, 01:25 AM   #2
Super Moderator
Grizzbob's Avatar
Not really sure what your question is exactly, but if you're wondering about what modes & settings to try, I'd suggest you start with using the P0 or P1 charge mode & do it at 1-1.5 amps(& do not use trickle charging, not needed & it can damage NiMh cells). And just make sure to keep a close eye on the pack to make sure it's not overheating(just in case).....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 03-15-2005, 02:44 AM   #3
ford_racing's Avatar
Send a message via MSN to ford_racing
just how hot can NiMh's get before they overheat and start damagiong the cells?
ARC R11
Yokomo YRF001
AE B5m
ford_racing is offline   Reply With Quote
Old 03-15-2005, 02:10 PM   #4
Super Moderator
Grizzbob's Avatar
Well, it depends a little bit on the weather where you are, but I'd say if a battery is getting any hotter than 140 degrees F then you may be pushing your luck(& many of use will base what kind of voltage drop we look for in a pack by the temp it reaches, if one gets hotter, then use a narrower voltage threshold so it won't get as hot)....
Bob Seay
Go Pokes!!!
Battery Charging Question xman Nitro On-Road 4 08-17-2008 09:03 PM
Battery Charging Question Section 8 Electric On-Road 3 05-31-2007 05:01 PM
Battery charging question... DotyThe8ight Electric On-Road 5 12-23-2006 12:33 PM
Question Please regarding charging battery Wing Chun Electric On-Road 2 08-26-2006 03:19 PM
Battery charging question tommytman Rookie Zone 10 08-31-2005 06:13 AM
