Spec-R R1
Old 05-12-2013, 02:38 PM
  #1456
Suspended
Originally Posted by spunkysandoval
I will pull the drag brake out of the ESC and see how it goes. I'm runing this car in a gt class at a couple different tracks and I just went with +6 because that is what my LHS had in stock.
I forgot to mention that I also installed the low friction belts on my car. The drivetrain is very free. The belts are adjusted on the loose side. The drivetrain on this rolls out better than my VBC
I run +7 hex to get the track width to 190mm with foams. The one thing to remember is that you have a spool up front, driving style here becomes critical to keeping entry speed up, if you go in to hard on the steering, you get the front wheels sliding, this will scrub off lots of speed, if your tracks are very tight, and you are still struggling for entry speed, you may find a gear diff up front is going to help you alot there, by letting the front rotate better.
RogerDaShrubber is offline
Old 05-12-2013, 02:57 PM
  #1457
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
He was running at the Tamiya America track which is a flowy high speed track. High 13-low 14 second lap times for 17.5.
IIGQ4U is offline
Old 05-12-2013, 03:11 PM
  #1458
edhchoe's Avatar
Trader Rating: 41 (100%+)
Finally done building it.
I had to use a spacer for the front for VTA wheels.
I love the battery holder
The only thing so far.... has been the turnbuckles coming off when I try to adjust the lenght. Do they come off easily during the race if you bump something?
*The rear toe in the picture was like 4.5. I changed them to 3.
edhchoe is offline
Old 05-12-2013, 06:31 PM
  #1459
miles514's Avatar
Going to give the shorty pack a try
I also did this mod (thanks for the idea) but when I tested my car, I noticed that I have problem with grip on my right rear tire. so I reconfigured the batt placement and add some weight up front to replicate the weight of the servo (well sort of...) And this is what i ended up, its working very well now...
sorry for the big pics..
cheers!
miles514 is offline
Old 05-12-2013, 06:39 PM
  #1460
Suspended
You need to either tap the threads into the ball ends, or run the turnbuckle right in and out a couple of times to cut a thread, then things will adjust easily and the ballends will not pop off when being changed.
Old 05-12-2013, 07:19 PM
  #1461
spunkysandoval's Avatar
Trader Rating: 125 (100%+)
Nice work! After driving it for a while I ended up putting the speed control right behind the battery. It is balanced like yhat.
Originally Posted by miles514
I also did this mod (thanks for the idea) but when I tested my car, I noticed that I have problem with grip on my right rear tires. so I reconfigured the batt placement and add some weight up front to replicate the weight of the servo (well sort of...) And this is what i ended up, its working very well now...
cheers!
spunkysandoval is offline
Old 05-13-2013, 08:51 AM
  #1462
Trader Rating: 17 (100%+)
Default Stock spring rates?
Anyone know what the stock spring rates are? other then red and white which doesn't mean squat.
Fish1 is offline
Old 05-13-2013, 09:27 AM
  #1463
http://www.petitrc.com/reglages/Univ...pringChart.pdf
I think the Spec-R springs are real close to the XRay springs.
I hand tested the white ones from the kit and they did feel right about in the middle of the Blue and Gold AE springs I had. And the red Spec-R springs are super hard. So the chart is probably right there too.
.crispy is offline
Old 05-13-2013, 03:07 PM
  #1464
Airwave's Avatar
Airwave is offline
Old 05-13-2013, 03:45 PM
  #1465
I need one of those ^
Old 05-13-2013, 04:23 PM
  #1466
edhchoe's Avatar
Those are expen$ive
edhchoe is offline
Old 05-13-2013, 04:59 PM
  #1467
rcdave1's Avatar
Trader Rating: 14 (100%+)
But they sure look good. I even opted for the red fan mount.
rcdave1 is offline
Old 05-13-2013, 05:22 PM
  #1468
R/C Tech Elite Member
JayL's Avatar
What they should do is include the alum spur/belt gears and charge MORE for the ultra light lower rotating mass plastic ones
JayL is offline
Old 05-13-2013, 05:33 PM
  #1469
DEE SPEED's Avatar
Default R1
any of u guys using xrays C hub for R1?
DEE SPEED is offline
Old 05-13-2013, 08:01 PM
  #1470
tiago890's Avatar
Believe it or not, I'm using the tamiya trf417 rear hubs and ront c hubs, works perfectly fine and a bit more durable.
tiago890 is offline
