Spec-R R1
#1411
+1 also try http://www.tap-die.com they have full sets of left hand machine thread taps.
#1412
Not to undo all the hardwork put forth in everyone's search for reverse threaded taps....but why not chuck the turnbuckle in a drill and slowly work the turnbuckle in and out of the ball cup. A drop or two of brearing oil....work slowly to keep the plastic cool. No money spent on tools if you already have a drill.
Taps are cheap and everyone should have a couple in their pit box in the right threads for their cars.
#1416
http://www.youtube.com/watch?v=XpXB6...n4lJw&index=13
Running Stock class 10.5t boosted.
TQ 6 qualifying and took the champ of the race
#1418
#1422
It would probably lower the rear grip but it also will give you a better cornerspeed...
There are only a few, but that's one thing I'm quite sure about...
#1423
Yesterday I had my first race with my S1. Finished first in C-final
Not because of the S1 (drove amazingly!), but because I´ve drove a zero-boost ESC in a boosted class.
The only option parts were 3racing Double-Joint-cardans, alloy-damper housings, steel pivot-balls and Tamiya ball-cups.
I had the cheapest car in the field, but was able to overtook some BD7´s during a 7minute run...
Regards,
Chris
Regards,
Chris
#1424
That was in fact the point of my question... I've never seen a such low cornerspeed... Did you try to use the inside hole on the rear knuckle?
Yes corner speed looks low but the driving is good
Paul
#1425
because i'm running ride 28r tyres in hot temp track...track temp is 60deg celcius..
i cant push much as i only have 1 set tyres for 3 amain final...
i vote to use 28r because it have better traction than other shore...like 32 n 36.
i flip the front and rear arm..to avoid hitting the wheel..im also running 2.5 toe in rear.
