Spec-R R1
Old 03-25-2013, 05:52 PM
  #1216
Potoczak's Avatar
Trader Rating: 120 (100%+)
Does anyone know if spec r has any plans on following the low CG route like xray or serpent??
Potoczak is offline
Old 03-25-2013, 06:01 PM
  #1217
Trader Rating: 64 (100%+)
Originally Posted by BajaSkidmark
I reamed the suspension arms, got them to feel real nice and drop with their own weight easily but without any slop. After tightening down the attach points to the chassis, they stay where you put them... Not hard to move them, but they won't drop under their own weight. Is this something that will wear in, or do I need to remove some material off the sides to free them up some? This is an R1, not an S1... thanks.
Make sure the plastic inserts are fully seated in the aluminum blocks. Also check that you have the spacers deburred and in the correct positions. You want them pretty free. They will loosen up some, but now is the time to practice building and getting it right.
I found the drive shaft blades to not slide freely in the diff outdrives. A very little bit of polishing freed them up. Details, details, details...
MC112b is offline
Old 03-25-2013, 08:57 PM
  #1218
BajaSkidmark's Avatar
Just decided to call it a night after finding the drive shaft blades binding some... then I read your reply. Go figure. Thanks for the tips!
BajaSkidmark is offline
Old 03-26-2013, 06:29 AM
  #1219
nrtv20's Avatar
I'm sure you could make your own shock towers and run x-ray shocks and springs if you really wanted to lower them.
nrtv20 is offline
Old 03-26-2013, 06:48 AM
  #1220
nrtv20's Avatar
Originally Posted by Bappe
good starting setup for med/high grip carpet, tha car is really easy to drive
http://www.scribd.com/doc/132318342/...-Mkeskil-Setup
I looked at your setup, for some reason when I run the Tamiya springs I have trouble keeping the cars ride height down. Did you have the same experience? Maybe it’s my build skills…
nrtv20 is offline
Old 03-26-2013, 08:51 AM
  #1221
i havent had any problems with the rideheight using tamiya springs
check the droop on your car, and lenght of the shocks
Bappe is offline
Old 03-26-2013, 02:20 PM
  #1222
Does anyone make steel/brass battery positioners? I will most likely need a little weight over there. I am busy as hell at work and don't want to make my own. Thought I'd get lucky?
MC112b is offline
Old 03-26-2013, 02:32 PM
  #1223
would be nice!
been searching for red alu screws, where can i find it? fastener express doesnt have 3*6 in either flat or buttonhead screws..
Bappe is offline
Old 03-26-2013, 08:22 PM
  #1224
DEE SPEED's Avatar
Default FIRST debut R1 indo carpet local race
1st place & TQ
13.5T Blinky mode class
GT Touring
DEE SPEED is offline
Old 03-26-2013, 08:27 PM
  #1225
Pit-racer's Avatar
Thumbs up
Awesome win there!
Pit-racer is offline
Old 03-26-2013, 08:50 PM
  #1226
metalnut's Avatar
Trader Rating: 36 (100%+)
Originally Posted by DEE SPEED
1st place & TQ
GT Touring
Could you post your setup please?
metalnut is offline
Old 03-26-2013, 08:52 PM
  #1227
Trader Rating: 84 (100%+)
when i had my car i actually did try out super low cg towers and shocks. car was very flat through the corners just needed better springs but i feel it would be alot better than stock. i ended up cutting the lower holes off of the shock towers and mounting them using the upper holes of the tower and fastening them to the lower holes on the tower mounts then i ran tamiya mini cooper shocks. just for a test of course. but now that the serpent is out i would get a set of the eryx shocks and try it as they can use standard length springs and are super short.
jeff jenkins is offline
Old 03-26-2013, 10:32 PM
  #1228
Does anyone run 21.5t blinky with this car?
The track I am on generally have a 3.5 FDR. Is that FDR possible with this chassis? What Spur/Pinion combos would I get?
Hars is offline
Old 03-26-2013, 10:49 PM
  #1229
metalnut's Avatar
I just started with running 25.5, but will be running 21.5 this summer I think. What's your concern? I'm currently running 45/88 for a 3.7 (since I suck ), but you could get 3.5 easily.
metalnut is offline
Old 03-26-2013, 11:25 PM
  #1230
Main concern is buying stuff that fits
I'm a total noob to on-road..
What brand spur are you using?
Hars is offline
