Spec-R R1
Old 03-18-2013, 05:08 PM
  #1156
bjanzen's Avatar
Just a question...... do you release the throttle when a crash is inevitable? Staying on power is going to make something break....... I am sure you know this but others reading may not. Just thought it should be mentioned.
The gear diff should help a great deal...... it allows something to rotate instead of snap.
bjanzen is offline
Old 03-18-2013, 05:28 PM
  #1157
90% of my wall contacts are early turn-ins on a 90 degree corner or high speed sweeper. If just a glancing blow it will cause me to push into the outside wall.
In other words, all at full throttle...
.crispy is offline
Old 03-18-2013, 08:18 PM
  #1158
Suspended
My Spec-R S1 arrived today, looking forward to getting it built and put on the track in 10.5T foam class.
RogerDaShrubber is offline
Old 03-18-2013, 09:14 PM
  #1159
Pit-racer's Avatar
TABUSHI what is the set-up on the S1? Can you find out and post some info?
Pit-racer is offline
Old 03-19-2013, 01:07 AM
  #1160
Pe4atnik's Avatar
Originally Posted by 32819toon
It's the stock Sport ones - I know they're cheaper but they still should hold up. I still think its the lack of movement in the spool and the driveshaft is taking the hit. Hopefully when the new gear diff arrives it will cure the problem.
My S1 passed trough more than 7 races and only thing I broke is spool cup went off (now I use +2mm screws in spool), 2 times front bumper (so I hit the car usually), arms and outside pins, but nothing in shafts. Maybe you should cut them on outside, not to hit walls with shafts.
Pe4atnik is offline
Old 03-19-2013, 11:41 AM
  #1161
tiago890's Avatar
hey guys, wife droped the R1 today and broke rear body mount, any one know if any other cars body mounts fit on the r1
tiago890 is offline
Old 03-19-2013, 11:52 AM
  #1162
Trader Rating: 15 (100%+)
Xray body mounts are the same. The Spec-R ones are obviously going to be much cheaper. I actually use the Spec-r Body mounts on my T3 2012.
puhrot is offline
Old 03-19-2013, 12:23 PM
  #1163
tiago890's Avatar
do you know if the HPI or AE will fit?
tiago890 is offline
Old 03-19-2013, 12:46 PM
  #1164
32819toon's Avatar
"only" in 7 races ! I'm worried now, I haven't had that many breakages in 5 years. Even my 10 year old hasn't broken that much & he's raced for 5 years - since he was 5 ! I'm beginning to think that this car is like racing egg shells !
Don't know what you mean by "cut them on inside" ?
I haven't raced the car hard as it's new, I haven't driven a spool before & I'm new to rubber tyres having just changed from foams. Too many changes to take in at once.
32819toon is offline
Old 03-19-2013, 12:57 PM
  #1165
Cut them on the outside. On most cars, there's a few mm of the axle thread that sticks out past the wheel nut, and also out farther than the outermost point on the rim. If that little bit of axle catches a board, it can bite into the board and cause way more damage than it might otherwise. He's talking about removing that extra material.
-Mike
grippgoat is offline
Old 03-19-2013, 02:06 PM
  #1166
32819toon's Avatar
-Mike
I understand now - good point about the axle sticking out, I had noticed that. Is the S1 narrow at the front than other cars ?
Old 03-19-2013, 05:04 PM
  #1167
Airwave's Avatar
Has anybody problems with the red aluminum servo support? First I believe it was twisted, but I think the problem is that my servo is way too narrow for the support, so it could move laterally...
Nobody with a similar steering problem?
Airwave is offline
Old 03-19-2013, 05:51 PM
  #1168
i have been using the central servo mount since december and havent experience any problems, not even after a full speed crash into a wall after the straight, only thing that happened is that the servoarm moved so the car was pushing badly to the left the rest of that final... problem solved with a xray servosaver im using a sav÷x 1251 servo btw
keep reading alot of the car breaking easy, for me this is like a tank. i rarely crash, but when i do its often at highspeed, only thing that has broken is a bodypost in the front, and when that happened i just touched a car after a lowspeed corner.
now i use a r1, the s1 has the same suspension so it should hold up just as well. im actually going to convert my car to a (r)s1, testing the glassfibre chassi and topdeck just to see what it does in handling due to more flex in the car. the r1 is quite stiff with the 2.5mm cf chassi compared to many other cars out there
since i made a comeback in touring i have driven 3racing sakura xi (very fragile, ended up being most xray parts in the suspension) ae tc6.1, car was a tank too, and now i use the r1 car, 60+ packs through it now and it keeps going strong one thing that i really like with it is the quality in the plastic, there is no more sloop in the suspension than when it was new (shimmed the suspension after the first practice, and its still the same) im running 17.5 boosted indoors on carpet.
Last edited by Bappe; 03-19-2013 at 06:42 PM. Reason: swedish and english dont work so well togheter :)
Bappe is offline
Old 03-19-2013, 07:29 PM
  #1169
Tabushi's Avatar
MANUAL Box stock setup, and i layed down 1 hole on shock tower down the rear shocks and used 40wt associated oil on all 4 shocks, THATS ALL ! ...
Tabushi is offline
Old 03-20-2013, 08:01 AM
  #1170
IndyHobbies.com's Avatar
Originally Posted by .crispy
And since I had left-over money... I had this made:
and the front...
Represent!
Too cool Gary, too cool!
IndyHobbies.com is offline
