Spec-R R1
#843
also use 5000wt it is tested and so far the best oil in my opinion. but if not 5000wt at least 3000wt. remember you need to tighten the diff enough to squish the o-ring inbetween the two halfs otherwise it will leak also green slime the xring o-rings inside the diff. do it very generously and it will be leak free.
#845
Does anybody know, if the "3Racing SSK 52mm Driveshaft for T3" (#T3-01) fits the S1?
According to the manuals, the R1 has 52mm Driveshafts at the front, but the S1 only 50mm Driveshafts? How can this be?
Regards from Germany,
Chris
Chris
#847
Hi, here's a few pics of the car....
#848
I had the same problem with the gear diff. When I put them together you could see light between the 2 halves. I sanded the side that fits inside the other and kept dry fitting with the oring and the gasket. Once i got it to the correct depth, no more light between the halves, I built it, inserted the screws. Initially the screws were too tight and bound the diff up. Backed the screws off 1/4 to relieve the pressure and it works like butter with no leakage. I also purchased a spec r Gear diff separately for the front and did not have the same problem. It went together perfectly. I think the mold for the parts in the R1 are off in size and make the 1 diff half too large.
I pulled the diff apart (left the gasket in) removed the oil, o-ring and internal (spider?) gears and sanded the "male" side of the diff down until the two halves would sit together without any gap.
I made sure I cleaned out the mess from sanding (oil + plastic shavings might bind the gears maybe).
Reassembled with oil and o-ring and no leaks
Thanks again.
#849
After reading this thread I could not resist buying an S1. I ordered mine through TQ RC Racing on Thursday and it was on my door step this morning (Saturday).
Wow!!!!! What great service! From west coast to east coast in a few days.
Thanks TQ.....will be a customer for life.
www.tqrcracing.com
www.tqrcracing.com
#851
www.tqrcracing.com
www.tqrcracing.com
#855
Trader Rating: 27 (100%+)
every time i drive this car its better and better! took 3rd in stock sedan today!
