Spec-R R1
#799
Droop should not have an effect on overall ride height as long as they are not screwed all the way in, compressing the shocks. That is really weird that it will not go down far enough. However the arm looks like it is way low. And you should not adjust roll center to try to get ride height. I suggest pulling everything apart, going through it, and making sure everything is working together properly.
#802
I know what you did. A guy at my track last night came to me with the same problem and he installed the oring on top of the spring instead of putting it inside the preload collar. Haha I'm assuming you did the same. Btw for people that have the s1 you should upgrade to the shock bodies from the r1 cuz the plastic ones suck. The same guy I was helping had them and one of his shock caps won't tighten because it strips out the shock body.
#803
#807
Trader Rating: 27 (100%+)
Hey I noticed you run sweeps in most of your set ups and was curious what have you done set up wise to put "side bite" into the car. personally ive gone to longer camber links front and rear.
#808
I shortens my wheelbase by moving my front arms all the way back. It shortend my wheelbase while shifting the weight forward. Also i am now running the shortest links possible with 4mm under front and rear inner ball studs. The camber gain I get from this gives mire side bite as well.
#810
doesnt hurt to try but i think they will need sanding as they are 4mm and i think xray is 3.5mm. doesnt take much use 400 grit paper and take an even amount off each side to keep the driveshaft as true as possible in the outdrive. you can use top photon blades if you want im sure amainhobbies.com has them.
